Mar 24, 2022
Hi,
I have a Seat Ibiza from december 2019. I already updated the Maps to the newest version. However I was wondering if it was possible to update the entire firmware of the MIB platform?
Currently I have:
Hardware: H50
Software: 0514
I need to upload the firmware for 6F0035871B (SEAT Ibiza Style 2019)
The last file/software is "MEN2_EU_SEGPx_P8010L"
Can someone give me the link to download the newest version, please.
Hello guys,
i'm attacihg screenshot of the firmware that i currently have installed on my Ibiza(kj1\6F), 2019.
how can i found out if there is software update available to install? currently im on version 515 as you can see at the screenshot attached.
Thanks !
Reactions: jteixeira1967
I can see there is a new version for the H41 units without navigation, version 480. I have version 479 and mine sometimes restarts on its own. Has anyone installed the newer version and does it have any improvements over the 479 version?
You have installed the version MST2_EU_SE_ZR_P0515T
the next version on this page ( https://mibsolution.one/#/1/9/MST2 - TechniSat Preh/Firmware/SEAT_ZR ) is the version MST2_EU_SE_ZR_P0516T_MU0516.
Yiu shoud downlod this version (MST2_EU_SE_ZR_P0516T_MU0516), unzip to a SD card and do upgrade
First of all - thanks for you help.
May i ask if there is a potential risk with upgrading the firmware version on my own? can i harm the system\multimedia?
Thanks in advance.
Thanks in advance.
There is always a risk, but what I was given to understand is that if it is a wrong version, the system will not update...
How to update Seat Arona MIB2 Firmware:
1. Download the update from the link you receive from us
2. Extract the update files using WINRAR or 7ZIP
3. Place the SD into the SD reader and format FAT32
4. Drag the files/folders within the download folder into the root of the SD card
5. Remove SD from SD reader and place in SD1 in infotainment glovebox unit
6. Start engine/(or just switch on ignition if your battery is strong)
7. Hold menu, press “software versions/updates”
8. Press “Update”
9. Press “SD”
10. Press the software version It presents then press start
11. Once update is complete, press back then cancel software version management
12. DO NOT REMOVE THE SD CARD UNTIL THE UNIT IS BACK TO NORMAL OPERATION
13. Once back to normal operation, remove the SD. You’re good to go!
hi, do you also have a problem with the speed of downloading the firmware from mibsolution.one? downloading the firmware takes up to 3 days :D something has been going on with the website for a month ;/
I just wanted to post a reply about this, it downloads like 60 mb of the file and then stopped, and i'm not able to resume...
I can update that the head unit firmware passed without any issues, worked like a charm.
Thanks for your help and instructions guys.
Hello guys, me again..
so as i already mentioned, the firmware update went well without errors, and everything functions without issues.
but, in the previous version i had the "sports information" fully working, i paid for it quite amount of money.
Is there any way to bring it back maybe with obd11? i've done everything as explained in that youtube video, but i was not able to open the "sports information" window...
and this is how it looks before i updated the version from 515 to 516 -
Thanks in advanced.
Reactions: JoseKaLeL
Hello i want to upgrade my ibiza system and i can't download the newer firmware on mib solution, it's so so slow.. impossible to download it :cry:
actual version : MST2_EU_SE_ZR_P0252T
i want to download this version : MST2_EU_SE_ZR_P0253T (the newer)
I passed many times and impossible to find the link.
Can anyone can send me a link or upload the file ?
Thank you much
Thank you much
I also had issues with downloading, i tried many times and finally it wotked. Try few times maybe it will eventually work.
Hi, i have the infotainment system and men2 version as you how did you the update where have you found the version pls
Hi I'm also looking for to update the firmware for my 2015 Leon Cupra 280. Currenlty running "MST2_EU_SE_ZR_P0241T"
but can't find a link to "MST2_EU_SE_ZR_P0253T" Does anyone have a working link they can send me please?
