Dec 16, 2022
Hello,
I have a cupra st 280 and it keeps blowing a fuse when I put it in reverse. In the photo its the blue 15A fuse in the middle. I switch to a new one and it works for a day or so and then blows again. When it blows I get all kind of error messages on the display like acc, tpms, parking censors not working.
Is it possible that it has something to do with a coil pack? I had one or two misfires on one cylinder this summer. Thankful for any help.
That's fuse SB34 and is for the Haldex front differential. There's two connectors to it under the car.
Presumably the fuse doesn't ever blow when moving forward?
The Haldex motor pump may be drawing too much current due to a poor connector, so check them for corrosion and being in place correctly.
Reverse must requires the pump to be in an usual condition to either fully lock or unlock the diff?
Reactions: cupra14
I will check the connectors asap. I always reverse out of my driveway and thats when the fuse blows, so maybe it will blow in drive aswell. Thank you for your help with the pictures and diagrams!
Reactions: Butty
