Yip, that's it. Held on by three small bolts. If it is rattling just now the plate will come completely loose quite soon. If you take the wheel off you'll be able to break the last bit free and pull of the plate. Then you can run without it until it's convenient to replace it.I'm I correct in saying that it's wheel off caliper off brake disc off then is it a case of just unbolting the plate.
I certainly don't think there is much harm in running without them for a while, maybe forever, but I like them to be there.Didn’t fit new ones, ok I maybe get more brake dust on the wheels but not sure, not an MOT requirement.
I checked mine (original alloy type) when I did my front wheel bearings and they were perfect - at around 100k miles and 6 years old.I'm guessing that these knackered ones are aluminium alloy?
If so, maybe a good reason to buy steel aftermarket replacements.
I originally was quite happy when I bought my slightly used 2011 Audi S4 in 2013, to see that it had unpainted alloy discs back plates - after starting to read many tales of back plates coming loose/free and seeing that most of them are alloy, I'm not quite so happy about having alloy ones now!
Rapidly dissolving aluminium alloy heat shields that you can repair with bits of tin plate is almost acceptable, the same thing happening with brake back plates/covers, is not so ideal.
