Leonfrdiesel184
158
37
Hi everyone time to change my rear discs and pads. I am going to get the brembo discs as they have been recommended previously and have been very good on the front. I installed delphi front pads so wanting to match at the rear but I don't know what size pads I should be going for. I search at parts stores and they come up with different sizes. I think the rears don't have wear sensors I am right ? Any help on the delphi product I need it would be incredible.
Thanks so much
I had to do a car vertical report to check what brakes I had fitted after ordering two sets of pads off my reg number that didn’t fit. What year have you got? Mines 2018 and ended up being 1ke which I had to compare to Halfords to find size…!
Reactions: Leonfrdiesel184
Thanks so much
I bought the brembo ceramic pads and they work great, they dont have wear sensors.
Sent from my SM-G981U1 using Tapatalk
Hi mate mine is 2018 like yours there are so many options when you look online its ridiculous mate
the ‘1ke’ dimensions for the pads and discs for my 2018 st if it helps -
That is amazing mate and a massive help. Sorry if I got this wrong isn't the rear system 1ks rather 1ke or is this dependant on what engine you have ? Thanks again mate
@SuperV8 - another one for you ?
lol.
For others this was my reply:
No rear wear indicator.
The 184 has 272mm diameter rear discs. 08.B413.11 looks correct.
There are 2x pad versions depending on if you have EPB?
LP2709 would be if you have manual handbrake.
LP2490 if you have EPB.
#Additionally# as yours is 2018 this has EBP so your rear pad would be LP2490 - which is 1KE pr code.
lol.
About bloody time lol lol amazing mate thank you so very much again I really appreciate your help
