hcuk94
22
I have a slightly odd scenario which I'm hoping someone might recognise.
My front wipers work as expected, until I park up somewhere, turn the engine off, leave the car and come back a while later - the stalk is still up in one of the 'on' positions, but the wipers do not come to life and stay in their resting position behind the A pillars.
I have to nudge the stalk to the off position, then back into the on position, and at this point the wipers will start up again.
Just wondering if this is a common problem and if anyone knows a plausible fix?
Thanks in advance!
EDIT: to clarify, I don't have auto wipers, the on positions are the basic interval with variable speed and constant settings.
Not sure if it is the same case with the non-auto ones but with mine (they are auto) the wipers will wait till you are back up to a certain speed before re-initializing. Not sure on what speed though.
Reactions: hcuk94
I’m sure our previous Leon did this too, I just got into the habit of flicking them off then on when moving off.
Reactions: hcuk94
I thought you might be right for a while as I tried being patient until I'd starting moving at speed and it came to life! But then after a couple more stops it never came back to life so seems to be intermittent.
Maybe it's a 'feature' then that I will have to live with ;)
Mine do this too so must be the way it was built I guess. Strange thing I’ve noticed though with mine is if the wipers are on position 2, slowest constant speed, and I hit 80mph they pause at the bottom of the screen. Maybe only for one second, but then carry on wiping back up the screen to the outer edge and back down again. Each time they go down they pause at the bottom before going back up. This only happens if I hit 80mph though. 79mph they operate as normal. No idea what happens over 80 though as that’s fast enough when it’s raining.
My Mk2 Leon is the same. Not sure if they come on at a certain speed. But through OBD11 I was able to set them to restart as soon as I moved off.
Don't ask me the procedure because I don't know how it happened myself :D
Reactions: hcuk94
I have OBD11 but as you say wouldn’t know where to start to fix this!
My workaround in the end is to just blip the wiper stalk back towards me (as if I was using the windscreen washer) which gets it wiping again and saves having to actually toggle the stalk down and back up to wherever it was again.
Reactions: GORDYDJ
Sorry to go off to topic. But yes, OBD11 can be a bit daunting. I feel it's partly down to the way some things are labelled. As I found out in regard to DRL/parking lights. Mentioned in my post here. https://www.seatcupra.net/forums/threads/drl-on-all-the-time.476073/#post-5057746
I still need help getting the dash lights back on.
To answer the original question. It's because the wiper stalks don't have a direct connection to the wipers, they just communicate with the computer and that controls the wipers. Must have been an oversight in the coding, that when the unit boots up, it's only looking for changes in the switch state, rather than checking to see what position it's in.
