I have just had a virtual cockpit fitted to a 2017 Leon, and have a issue with the fuel gauge, and range seems to be slightly out.
With the old cluster, the fuel level used to drop in segments and then the single segment used to turn red when the low fuel indicator came on.
Now the segments drop until I get to 2 segments remaining, it then drops straight to a single red segment when the low fuel indicators comes on
Using VCDS I can see Controller 17 Byte 2 has 8 choices for fuel tank type. Mine was set to 2 and I have now tried setting to 3 instead.
Does anyone know what the 8 different choices refer too?
I am hoping to match the capacity of my fuel tank (2.0TDI 150BHP) with one of the choices if possible, failing that I guess the hard way is to try each one in turn.
