eastyorkshireretrofits.co.uk
Yes it can be activated, we need the vehicle or the infotainment unit here to activate itmy multimedya sytem is media system plus. Is there a full link to this?
You either need to buy an activation document and have a specialist such as ourselves or your local dealer activate it. We can't do this for you as we need the car here.I live in Turkey, full link prices are very expensive here, so I'm trying to do it myself, so as not to break the unit, I'm trying to get help from someone who knowsMy English is not at a high level, so I'm looking for someone who can explain step by step, I would be very happy if you can help me.
Tell
East Yorkshire Retrofits
It would appear like that. Last sentence aboveAs far as I understand, I cannot do it myself, is it true?
He has MIB2 standard without Nav. Due to the unit variant, it cannot be activated via SD card which means connecting directly to itIt would appear like that. Last sentence above
"Or open the unit up and connect to it internally to hack it"
That's the traditiinal retrofitters way of hacking without the official license. It will be putting it on a laptop, shorting pins and using a specialist piece of code. The password to get into these units via a laptop got cracked... but what you do next I pass. You would need an Ethernet to usb adaptor. That's how the procedure works. A program etc. It was the domain of Russian / Polish retrofitters. They sold their programs onto each other or swapped them.
DIY methods using toolkits put these programs into the green menu using the POI exploit. Hobbyists did that. Giving the programs away but you are snookered since your unit doesn't have navigation on it so the POI exploit can't be used. Ditto with modified firmware which uses the POI exploit. No POI import capability no way of getting programs into the unit without the retrofitters conventional way of doing it on a work bench, a usb / Ethernet adaptor and a program to get into it that way. You might find something online. That's all old school stuff now. Digital Elite board in German would be the place to look.
Could be this thread ?.He has MIB2 standard without Nav. Due to the unit variant, it cannot be activated via SD card which means connecting directly to it
There's no password when connected to the EMMC, and there's no need for a USB to ethernet adapter. It isn't activated via POI either
