Akrateca
8
9
Netherlands
After a lot of research and bought wrong airbag slip ring parts it finally worked all.
Start and modus button works fine.
Can you share the how-to of this project?
You need 3 parts for it.
- 5Q1953549G airbag slipring
- 5Q1953507GG stalk
- Cable set Kufatec ( need tot repin it)
After install connect wires for start button to excisting start button. To let work the start button on the steering wheel.
For the Modus button you need to reprogram in databus 19. With odis or vcp.
Thank you!. I'm having trouble identifying the Kufatec cable in their website. Do you happen to have the code for it.
Ah!...and I'm missing the actual wheel with the satelite buttons (VAG part?)
- 5Q1953507GG stalk
Hi Mate,
Can i ask where you sourced the 5Q1953549G airbag slipring.
Im having trouble finding it except direct from Seat who want £450 for the privelige....
Thanks!
If there is no heating, the slip ring needs to be replaced, wiring added and coded. The same goes for the start button.
Sleepring moet je vervangen, stuurwielverwarming blijft werken. Ook heb je een andere airbag kabel nodig en dataset voor de modus knop.
Dus alleen een stuur met die knoppen, esp knop(ter vervanging van startknop), sleepring en airbag kabel? En als ik voorheen geen stuurwielverwarming heb zal dat nu wel werken?
the language in the forum is English! and as I already wrote, if there is no heating, tighten the cables and code them and of course protect them extra
Ja en de bekabeling voor de stuurwielverwarming aangezien je deze nog niet had.
Yes indeed. You also need the cables for steeringwheel heating as you don't have it yet.
I couldn't find the forum rule which states that english is the only language which is allowed to be used on the forum. I have seen you using german in other threads. Nevertheless, thanks for your addition to my answer.
I couldn't find the forum rule which states that english is the only language which is allowed to be used on the forum. I have seen you using german in other threads. Nevertheless, thanks for your addition to my answehoi,
Hoi, en hoe zit het met de esc knop .....ben op zoek na diagrams voor de esc knop en de mode knop
