samm
Oil be back!!
Nov 5, 2003
498
7
Horsham
sammullahy.50megs.com
Morning. I have had my VZ2 310 for a while now and there are bits I love and lots of bits I don't. One thing I am not a fan of is the transition from low to high beam. Compared to other cars I have had, it takes an age! This is particularly noticeable when you try and flash the lights. It's like they are drunk as they are so slow. I have had people not notice I have flashed the lights. Is this another quirk of the Formentor?
I think it’s the type of light. I’m not sure if you’ve had a car with LED lights through a lens, but the lag is the lens physically moving to raise the beam. Rather than a separate bulb like a halogen setup. Or at least that’s my hypothesis!
I feel your pain. I think the range of the full beam is not very great as well. I've had the garage check it out and they say all is fine. so i'm wondering if i can manually adjust it myself.
I agree with you. There is no instant reaction as there is obviously something moving...slowly! It also pisses drivers coming in the opposite direction when it takes and age for them to change when the auto lights are in action. Ho hum!!
They are slightly faster at tilting then the Matrix LEDs I had on my previous Ford but yeah, I'm used to holding the flash down until I can see the beam reach the drivers eyeline.
Indeed, when I try to flash it seems crawling-slow...
However, when driving in dark conditions and when the High-beam-assist has to switch between the two positions it doesn't seem that slow anymore.
Maybe it's just me...
that's also my perception. I think it's the same LEDs used for both beams, and the computer is just changing the height via the leveling system. That's how I see it on the non-Matrix headlights of my Formentor.
However, on Octavia mk4 I had the Matrix (which is way better than the Matrix on the Formentor) and it was really fast; not to mention that you could see separate sections in the headlight for the high and for the low beam.
