Different product masquerading as
Obdeleven. These dongle companies wanting to get in on the action. I know Syphon used a dongle once after an airbag light came on with fitting a camera.... they aren't
coding dongles just scanners. Syphon's cleared the air bag light, I remember with that dongle. Not a proper
Obdeleven device. Mind you I'd say buy
Obdeleven and get the pro if you tinker with cars. If it's just for
coding you can allow the pro license to drop once you have done the
coding, Cheaper than
obdeleven without the pro license but using the black box micro payment apps. That end of the market on the same device is to take on the dongles that don't offer
coding. The vast majority of them.
It's a lesson you learn not to randomly pull fuses if you don't know what it does. I learnt it on my Altea when it refused to start it was dead. There was power to it but turning the ignition did nothing. It was an under the bonnet fuse that that I pulled that caused the air bag light to come on. Alteas mystery electrics, the car started the next day but the airbag light stayed on. The
dealer cleared it for free when they were checking out why it was playing up on starting. In retrospect it could have been the immobiliser playing up. Think they reset after a day or something
. Talking about 20 year old car electronics in the Altea.
When we say mystery electrics a few years later I had a bout on headlights "on" with the switch turned off. That lasted a few days and fixed itself. Dampness probably. Altea the
dealer said has an electrics control box that is temperamental (one of those high value things). By that stage the
dealer had the habit of charging for diagnosis so I didn't bother with the diagnosis given that it had cleared itself.
Generally you are suppose to pull the battery if fiddling with the electrics for this reason but as said in the previous post you then have to retrain the windows so they drop on one touch and the mirrors fold in and don't stay out if they work like that. It's one touch that has to be reset.
Edit.. found the post now... cover one touch in that as well.
Had the passenger side panel off of the dash today, while fitting a dash cam - the one with the passenger airbag disabling key slot. As part of that, I disconnected the actual switch to be able to remove the panel. Everything is now back together as normal. Since then, while starting the car...
www.seatcupra.net
Reckon it was this one Syphon used
