Jun 17, 2024
Hi everyone,
I've decided to install subwoofers in my 2020 KL1 right-hand drive Leon. I've tapped my RCA into the audio wires on the driver's side kick panel, but I'm having trouble running my power cable. When I ran the power cable to the passenger side footwell and removed the carpet and panel, I couldn't find a way through the firewall to pass the 0 gauge wire.
I watched a video on a Formentor where the guy found a grommet, cut it, and pushed the wire through, but my Leon doesn't seem to have that. I even removed the battery and some foam in the engine bay but still couldn't find anything.
If anyone knows where a pass-through in the firewall is, I would really appreciate your guidance on how to find it. Any help would be greatly appreciated. Thanks!
Hi there,
Thanks for your reply to my post. I have a couple of questions. First, is there a grommet located down and slightly to the right of the ABS pump, or is that the best place to make a hole? Secondly, I removed my battery, but there doesn't seem to be a lot of room. Do you have any suggestions to simplify this job? Also, will the grommet be visible, or do I need to remove the sound deadening material? I appreciate your help with this and will be purchasing some items from your website for this job. Thanks.
