rohank99
37
16
How simple is it to upgrade from halogen to LED taillights? Is it a case of unplugging one and plugging in the other or is there more work to it. Looking to upgrade mine and get the nicer looking LED taillights.
Not as easy as that - you will need to run extra wires down from the high level brake light to each of the new outer, body mounted LED light clusters as the wire for the brake lights is missing in the halogen units. You will then have to go into the configuration settings of the light clusters (address 09 central electronics) with VCDS or similar and reconfigure each light allocation to LED rather than standard bulbs
Have you done this process before? How hard was it
i was able to do this but so far i’ve only done the tailgate ones and not the outer one, waitin for the outer ones to come
Have you fitted the outer part? Does it need wiring or just coding
i have put an outer one, sadly the brake light doesn’t work as the halogens use the same wiring as the drl so i will have to get a harness to connect the outer to the brake light at the top.
Sorry to bring this up. Do you splice in to the 3rd brake light or is there a pin for that?
