Rattling / buzzing noise from the dashboard
Feb 27, 2025
Not for Leon but you will get the idea
Use some plastic to pry it for start to not scratch dash but once you lift a corner you can use hands to pull it up , work ytour way around it, only few clips holding it.
Reactions: georgemilev
georgemilev
33
thanks sir i will keep the thread updated when something pops up!
georgemilev
33
Hello All,
Last week i have disabled the soundaktuator via obdeleven and since then i have only heard this buzzing once and it was very mild, nothing compared to before. I have driven only 200 km, so it's not much, but... My question is - is there something mechanically that can screw up with this and even disabled to cause this?
Thanks.
Georgi
georgemilev
33
Hello all,
Another update on the issue. I can safely confirm that the issue is with the plastic that is around the air vent. Today my gf drove the car and when the issue appeared I started to push it down and it stops. The question is can I remove any plastic from the dashboard without removing the whole dash? Any idea how to approach this?
Georgi
Cubbington
194
161
UK
Hello all,
Georgi
Great that you’ve found the problem!
That sounds like a big job, which air vent? You may be able to remove it and put some felt tape or foam around it to get rid of the buzz.
georgemilev
33
Sorry I missed to write down that' it's the big one that is towards the window in the middle of the center console
Cubbington
194
161
UK
No need to apologise buddy 🙂
can you put something in between the windscreen dashboard to pad it out? Maybe some anti-rattle tape pushed in with a trim removal tool? You could try first by putting a long piece in that you can pull out (don’t remove the sticky backing tape!) if it doesn’t cure the problem It’ll be fiddly, but that’s got to be worth a try.
georgemilev
33
I think I can but it would bother me visually I would prefer for a more gentle solution hence the question can this plastic be removed so I can put something below it and not to see it
Cubbington
194
161
UK
I didn’t mean it as a permanent fix, just temporary to see if that fixed it, then you could do a proper job.
i couldn’t live with that mess either 😉
But agreed, if you can pop that air vent trim off, then that would be the ideal solution.
Hope you figure it out!
georgemilev
33
What would be your suggestion for a proper job? I can't imagine to do anything if I am not able to take this plastic off without removing the whole dashboard / console. Do you have by hand the workshop manual? At least there I can get more info on removing this (hope so)
Cubbington
194
161
UK
The only thing I can think of is to push some anti-rattle tape in the gap between windscreen and dashboard temporarily- don’t remove the sticky backing and leave a long length showing so it can be pulled out and done tidily somehow if that cures the problem.
If that does work, then you can figure out a way of doing it tidily.
Otherwise, you’ll have to figure out how to remove the air vent. I gave mine a little pull at the corner a few days ago to see it would unclip easily and it didn’t want to unclip, so I didn’t force it. You also don’t want to risk something snapping off and falling down the vent as I doubt you’d ever get it out…
Hopefully somebody else will come along with a better suggestion than mine, and how to remove that air vent.
Cheers,
Nick
Craig.
The artist formally known as ViperSlider
Mar 26, 2024
355
319
Cardiff, S.Wales
Hello all,
Georgi
Have you got a pic of the exact part you mean? Ideally with arrows or a pointy finger to be specific on which part is rattling :)
