OBDEleven Formentor - See below for working ones
cairus
1,673
588
I have direct access to someone who has OBD 11 with a lifetime license, just like me. He got a new car, a Skoda Octavia Combi facelift, produced in February. He was able to scan the vehicle normally with the VAG app. Only the error log of the SFD 2-protected control units was partially without plain text.
tracktoy
Committed Cupra 280 Track enthusiast
1,037
820
UK
I would stress I am an OBD11 Fan and I hope they (I suspect its VAG rather than OBD11) get it fixed but saw this today.
Tell
The latter I guess are what the crowd sourcing disciples are seeing. The guys that write apps by paying extra to do that, that may not get properly tested on the specific car and lead to problems... are locked out of development at the minute. That's my reading of that. Well any sensible person should code it rather one click. So they have been parked until SFD2 is sorted on Obdeleven. Obviously business as usual on all models till 2024 with SFD2 on it.
tracktoy
1,037
820
UK
I agree you should do your research and code manually but what supprised me this morning was this on the OBD Site
Based on what I see on the OBD11 Forum I dont think you can call OCA RISK-FREE
tommyfulf
55
Is there a way of turning off the eco assist? I turned the tips off but I'm wanting to turn off the annoying foot off before a roundabout etc
tommyfulf
55
I'll have another Google and look through the manual but the only setting I found you can disable is the eco tips which is not the foot off coming up to the roundabout that's apparently eco assist and I can't find a setting anywhere
the_winner
41
12
34
Athens,Greece
I am sure that the messages for roundabout , traffic in front etc is from when you use the maps , check the maps settings
the_winner
41
12
34
Athens,Greece
I am 90% before i complete the Trailer Assist for Formentor MY2022 , i only need SFD for the 5F Infotainment to enable the Trailer Assist to show it at the infotainment . I will do it and i will post the results
Reactions: xronical
tommyfulf
55
I've managed to code things in A5.
SFD auto unlock is activated.
When trying to change settings in Module 13 like turn on cruise control function on my Formentor I constantly get "something went wrong" any ideas or work around.
I've tried bonnet open, ignition on, door open
Bonnet open, ignition on, door closed
Bonnet open, engine on, door open
Bonnet open, engine on, door closed
And all the above with the Bonnet closed.
tommyfulf
55
Ive logged the question. Euth their contact us support function, haven't heard anything yet.
I'll also do the obd11 forum though
Reactions: Tell
Apr 8, 2025
Did you plug in the charger cable? that was what did the trick for me. Bonnet open, charger in, ignition on.
Reactions: Tell
tommyfulf
55
To fix the issue I had I went into the options menu and had to input the 6 didgit code again. Once I confirmed the unlock code it allowed me to save any settings I was trying to make
