Mk3 SE Headlights Upgrade
rohank99
37
16
So I’ve got the mk3 Leon SE which obviously doesn’t have the LED headlights and instead has the halogen bulbs. I wanted to know if there was any way of installing that LED design into my current headlights to match the look of the FR facelift ones, I’ve got a picture of my headlights down below. Not sure if this is something that would require an extreme amount of work or if it can even be done, just curious. Thanks
rohank99
37
16
I’d want to fit the light strip in to make it look somewhat like this, just the general shape of the LED.
LeylandVCDS
621
376
Leyland, Lancashire
Not worth the cost.
In fairness to what @Glosphil says, my last Leon was a preFL SE Technology with the full LED headlights. My current Leon is a facelift SE Dynamic, with standard halogen headlights. Yes the headlights on this are obviously a bit more yellow than the LEDs of the old car (though helped by changing the standard bulbs for Philips Extreme Brilliance), but the actual throw of the halogens is far superior to that of the LEDs. Out of preference, apart from the colour, I actually much prefer the halogen setup........now that's poked the hornet's nest, expecting some pretty negative replies about that statement!:D
Reactions: Walone
Nov 6, 2024
Rockbox
167
56
The led lights on a pre facelift Leon are s@@t for light output and seeing in the dark they are even worse if it's raining.
If you are wanting to do this retro fit for light output then as said above swap out your bulbs for some decent ones as they will put more light on the road .
The only advantage led lights have over halogen ones is they look ok.
Reactions: LeylandVCDS
LeylandVCDS
621
376
Leyland, Lancashire
Agreed wholeheartedly with what @Rockbox says above - I swapped my original bulbs for Philips X-treme Vision Pro150, and the difference over the factory bulbs is massive. And way, way better than the LED of my previous car.
The X-treme Vision Pro150 bulbs are a straight swap with the original bulbs, and a totally safe upgrade with the bulbs staying at the same 55W, so no coding required, and since putting these in, I haven't had one single objection from another road used with regards dazzle (which I did constantly with the LEDs of the previous car). Having had both setups, if I was to change the Leon again, I would certainly go for another with halogens over the LED.
These bulbs aren't cheap, but are worth every penny - I've got them in both dipped and main beam (H7 bulbs for both). They are noticably whiter than standard bulbs as well.
Here's the link to the seller I got mine from.
Nov 6, 2024
Yeah I get ya, its not the light really because any brighter the oncoming traffic gets beamed even on low beams. If its anywhere the same as halogens but with a cooler look I'm in. I've the L90028086 MBD DRL LED Modules on hand for both sides (not auto leveling ones). I'm just trying to find the perfect mind that can install them without errors. PWM Pulsing Fix Anti-Flicker Capacitor Link | HR H300 or GTR PWM Interface Modules promise a lot but will they work tho :rolleyes:?
LeylandVCDS
621
376
Leyland, Lancashire
That's just it though, the brighter and whiter halogen bulbs do not get any objection from oncoming vehicles. Standard LED setups do get regularly flashed by oncoming vehicles on dipped beam.
You can't just fit a set of LED headlights - without the self levelling you will have endless issues with dazzling others, and they will not pass a yearly inspection either. LED lights cannot be manually adjusted, and need the level sensor fitting and working.
Those headlights you've put in your post are from a pre-facelift Leon, and they are known to be absolute crap as far as light throw goes. My previous Leon had them, and they were atrocious, especially in the rain. Changing from your standard halogen lights to a lower light output LED unit just because you think they look better really isn't the way to go. And putting aftermarket stuff in to try to fool the canbus into thinking things are standard can be a very costly mistake when the BCM gets fried.
Reactions: SRGTD
d_taddei2
25
Scottish borders
Thanks for the reply I believe there are single filament bulbs it's either a 380 or 382 bulb I guess their is no upgrade. On the face lift models do you know if the LEDs are 6000k?
d_taddei2
25
Scottish borders
Most factory led headlights are around 5000K
Do you have websites that sell 5000k to fit 2014 plate model. All I can find is 6000k from abroad that states won't bring up fault codes. For £26 plus delivery costs. Surely must be a UK website selling 5000k but I can't seem to find
LeylandVCDS
621
376
Leyland, Lancashire
5000k and 6000k have very little difference between them. 6000 is just a touch more pure white on the bluer side. But honestly, I would look at just upgrading with better halogens - firstly you need to make sure any LED bulb will physically fit within the headlight casing - many don't because of the big base, some of which have cooling fans built in - and from experience, yes they look well, but light output is poor, and the beam pattern atrocious to non existant with after market LED bulbs that are (illegally) fitted into a reflector light that isn't designed for an LED bulb. Not only are they anti-social with very poor spread of light, they are very poor in performance compared to the standard - as well as not MOT acceptable, and a magnet for the over-zealous traffic police. Finally, they are described as non-error - this is because they have built in resistors to fool the canbus that standard bulbs are fitted. That's all well and good if the resistors are actually the right resistance. If they are not, there is a real risk of frying the BCM control module in the car, which is not a cheap repair by any means.
Yes I did try two different sets of LEDs in mine, but very soon went back to standard halogens which I upgraded to the Philips 150 Ultra Vision bulbs, which, being standard bulbs, are safely plug and play. They difference over standard factory bulbs is literaally night and day.
Think very carefully before risking damage by fitting LEDs.
Reactions: d_taddei2
d_taddei2
25
Scottish borders
Ok thanks for the info. Yeah I am only after the daytime running lights. The high and dipped I have ordered those bulbs you mentioned. But my daytime running lights are pure yellow I was looking for something that was a little less yellow and more closer to white, but it seems only LED replacements is only option that I can find. Would it be ok to fit only LED to the daytime running lights and replaced the other lights with the Philips bulbs. ?
