New Firmware Seat Tarraco software: 883
Antera
343
129
Breda, Netherlands
Www.vcds-coding.nl
Took some time but there is again a new firmware version out for the MIB3 wich is mounted in the Tarrcao
Its the Software version 883
Its a little bit faster and also some little bugs are gone.
For more info contact me with a private message
Reactions: Tell
x21_jaf
13
This has come up on my Tarraco as an over the air update today - it has downloaded and is installing at the moment.
Over the Christmas period there was an other over the air update to - update the apps - it took a few minutes to download and install. Not sure if this is needed before 883 update.
Apr 9, 2025
I updated my Tarraco from 782 to 870 and now I have problem with my retrofited rearview camera. Screen is blurry and I presume it's some coding missing what update removed. Can someone help?
Apr 9, 2025
I got the firmware from mibsolution. Also camera was working with 782 software. Only after upgrade from 782 to 870 got blurry. Camera is bought from Navlinkz Germany. Reseller who installed the camera told me to rollback the software and it will work again, but I don't want that as older versions had many bugs.
May 7, 2025
Hi i am from Türkiye.
I have 2023 seat tarraco. Everything is great. But i have a small infotainment problem. Since first Day brand new my tarraco multimedia vibrates and makes me crazy. It happenes always during engine start. After Hard reset and some times 2 or 3 Hard resets it gets normal.
Local dealer did nothing but wait for new update. Today They updated from 0870 to 0883.
But nothing has changed. I have some friends with same tarraco with same eqiuoment. Non of them has this issue. Even with lower verison of software.
I dont know what to do. Waiting for suggestions. Can it be beause of hardware or Only software issue like dealers say.
I couldt add video. It is seen there.
serdar_18fr
560
I assume it's a vibration on screen?
I don't think a software issue would fix itself after a couple of hard resets. It sounds to me like a hardware issue. I would push for a replacement, if its warranty isn't expired yet.
Tell
Probably not clipped properly at build. Things do get missed out.... unless we are talking about a fan in the actual infotainment unit catching on something. The curse of old PC power supplies.
Either physical shaking of a unit or a fan catching. My two penny's worth.
