Facelift LEDs are much better, especially in terms of optics. I switched from pre-facelift LEDs three months ago. It wasn’t easy, but now that the work is done, I can say it wasn’t particularly difficult either.
Everything was done by me, except for the CP removal, which I had help with (no odis online account). Contrary to what was said here, it is doable on your own. I don't have any special skills when it comes to working on cars. After doing the backlight retrofit and upgrading the radio from 5.8" to 8", this was only the third retrofit I've ever done.
(The total cost of the headlight retrofit was under €1,300 — not including the cost of the ODIS China clone and VCP)
Personally, I think even the LED facelift headlights are bad, considering what other manufacturers brought to market during the same production period.
Reactions: LeylandVCDS
View attachment 48774View attachment 48775
Did you have to change the bonnet and bumper to fit the facelift lights? Seen a few posts that say they need to be changed.
That is not true. As you can see in my pictures, it’s the stock pre-facelift (Cupra) bumper and bonnet. The headlights are exactly the same size and shape, so no modifications are needed. Of course we are speaking from Leon3 pFL to facelift and not to Leon4.
Hello, How many people on here have actually attempted or have done a pre facelift halogen to led headlight retrofit?
I’ve already done the rears which was easy enough but onto the front, I was gifted a set of front LED headlight for free by a friend and would like to attempt a retrofit. I have vcds and coding isn’t a problem? But is it a direct plug in or have i to do wiring on the pins? I am also aware of the level sensor.
Ripon can you send me the pins needed for the rear halogen to LED it would really help me brother. I want to retrofeit them. I have standard Seat Leon 2013 woth halogen lights and was given a ser of 2013 LED rear tail lights and want to retro fit them. Your help is appreciated brother!
Bjr à tous
Moi j'ai passé du phare halogène phase 1 au phare halogène phase 2 tout fonctionne correctement sauf DRL LED du jour j'ai codifier correctement les leuchte 5&4 mais pas de résultat
Mon BSI et 5Q0 937 084 AC
Phare monté 5F1 9410 015
Bjr à tous
Reason could be because headlight needs 2 12v for drl, one on the wiring then another is connected to your BCM
