Que? ?Ragazzi, come faccio ad avere il codice sostitutivo per il pneumatico lato sinistro (lato conducente italiano)?
Hi Giuseppe ?
Do you have the motorised tailgate?
Yes, I have a Garmin minicam 2 wired to the 12v socket. Can be done fairly easily. Run down windscreen side of A pillar so barely visible. Then under door sill trim.Has anyone fitted one of these just by running wire in edge of trim, plugged into the 12v in the arm rest?
Considering getting a nextbase but not wanting to take the car apart to hardwire.
Cheers!Yes, I have a Garmin minicam 2 wired to the 12v socket. Can be done fairly easily. Run down windscreen side of A pillar so barely visible. Then under door sill trim.
Hardest part is getting cable under passenger seat rails to the centre console.
I went out and braved the frost n sub zero temperature take a pic of the left boot lifter but it's covered in a plastic outer so I couldn't find a part No. for you.
about 2 weeks ago I had a dash cam fitted by halfordAre you using parking mode on that dashcam? It's the only thing that could partially drain your battery and lead to those errors. Otherwise there's no relation to camera installation, and it's a pure coincidence...
