Fitting aftermarket amp in Leon Mk3
Chariot
41
13
Hi Folks
I'd like to add an aftermarket amplifier (amp) and it would go under the passenger seat. I have a few questions though:
1) Has anybody undertaken this before? Does our forum have a thread I could use as I used the search button and couldn't find a build guide
2) Could anybody provide me with a guide on how to remove the passenger seat (heated)?
Here I guess it will be a case of disconnecting battery, loom and then unscrewing chair, but it would be good to have pictures of what the loom looks like, how it clips, so as not to break anything in the process. And having pictures of the bolts under the seat and torque settings, wouldn't be a bad thing either
3) Securing the amp: What have folks opted for, when fitting under the seat; I would want to avoid drilling in the floorpan, so what can you advise? what is known workable solution? Would it be better to remove the carpet?
4) Cabling. The power would come from the battery through the passenger footwell (this forum has details). But then, how to remove the passenger door lower trims? Are there DOs and DON'Ts
Anything I have forgotten? Please feel free to add with relevant info
Chariot
41
13
Please don't be angry, but take a look at your seat in peace, then some questions will usually be resolved by themselves
No anger here Cairus, . (yes, I am asking the questions before even looking at the car)
I that is what you are saying, then understand that me looking at the seat and looms, doesn't trigger the same clarity as say - if you were to look at it.
Hence why it's important (for me) to collect existing knowledge, from fellow enthusiasts, as there is much to be gained from more experienced folks.
It is also an opportunity to gather and label all the info, so as to increase our knowledge base and find it all in the correct place
For example, to remove the kick panel, do i need to remove the bonnet lever?
cairus
1,603
559
then I recommend to invest a few MONEY at "ERWIN" and to buy the vehicle documentation
Chariot
41
13
Erwin won't tell me how to attach an amp to a car though; that is what a community is for; sharing experience, mistakes. Point is that our forum does not have all the information available in 1 single thread.
Walone
1,722
509
Near Heathrow
Hi Folks
Have you looked to see if there is room under the seat? Some models have a storage box under the front seats.
Chariot
41
13
Hi
Yes, which is why I needed some pointer on "how to".
But basically, remove the trim, lift carpet and insulation and the I found that, between the seat harness connection point and the air duct (leading to the rear footwell), there is space.
SuperV8
1,884
950
Why do you want to put it under the seat - and not in the boot? Presumably its an sub amp?
Cubbington
194
161
UK
I went for Audiotec Fischer Match in my Octavia, with a VAG loom; it fits inline of the existing system, and as it’s a Class D amp, it’s tiny, no bigger than a couple of fag packets, and I fitted it behind the MIB screen.
https://www.audiotec-fischer.de/en/match/amplifiers/
Can be as simple as plug’n’play, or fully software customisable and EQ’d (which I did), plus a lot more…if you hunt around the Briskoda forum, you’ll find my Covid project!
Car ICE has come a long way since having to install massive amps and run lots of cables everywhere!
Hope that helps.
Cheers,
Nick
SuperV8
1,884
950
Hope that helps.
Cheers,
Nick
Interesting read:
Reactions: Cubbington
SuperV8
1,884
950
Exactly! And it’s reminded me that I may just do the amplifier again, but on its own!
Ah, yes I read that comment - about a big difference just with the original speakers with just a decent source from the new amp!
"Back in the day" (i'm talking when 106's and Saxo's were new!) we fitted a really nice Pioneer head unit into my mates 106 and the difference in standard crap door speakers was amazing - with just giving them a very decent input.
Cubbington
194
161
UK
Thanks, and yep, you got it spot on back then 😃
I’ve been in the HiFi industry all my life and it’s “Crap in, crap out!”. Always spend money on the source, as a pair of great speakers will only show up a bad input and amplification!
Dammit, you’ve got me going down the upgrade path 🤣
Reactions: nd-photo.nl
SuperV8
1,884
950
I used to work for a HiFi shop helping on their high end installs, trouble was the owner had an amazing setup, huge B&W 801 nautilus and some ridiculous amps, and once you hear a nice system its hard going back :ROFLMAO:
