ND-Photo.nl 's - Seat Leon ST Cupra 280
nd-photo.nl
4,354
454
The Netherlands
youtube.com
Tried out a wide angle mirror. You can see everything from one glance, but I could not get used to the field of view and it made me a little nauseous:stars: So I removed it again
Also with a "stick on" mirror you lose the self-dimming feature off course
AP1GczM3_qsIMTx1nGPkGcg2tP9rDGjHmC4ZQj4AkNxzVHmyVbiagLLy4Nw2LAtQS3dWnvMlWSZbqIYotcjjsnTz8SOe4S2Hvb1egM_tut5D_ui1Id4ypGobGLF19gcJkSyMGChiVKnc-eVjiK8qDKO-hsu-yQ=w1920-h1080-s-no
AP1GczN7mMAw-SyOYBAaPr4-QcsQ8LV7cwGJCvh5QRwdhSTwzPhIGYDM0d1nG7XX5d7Tm6j5CZbFor7-i5OA-IPPBGJOf1ptOe-g7SINWY2rzR1Dt4cNC6VqYC_nlKQkDEiOylBRyDBIyiUzXoIapNWqnUDR8g=w1920-h1080-s-no
Normal mirror
AP1GczMqcqSTkdqCGiWLaOx3wHyaz0Dz17ohtZKLoM2W_enDWSryqkDCsD2GWASk1nUXsyX4docu8au4RdSmiWppWQXofcaAX57iE04W0R5PZ2l0Am9toSn0E1IG3HeZGw24d9i88zRhds9U9J5yUWKNsld69w=w1920-h1080-s-no
See alllll the things!
AP1GczNgfN4fc6dy6wuG6rPNhRHxmK3zeIIRRfEDytMYQJ0hZVlA193N54GAVD7gSFLT_FUYnXljbReYN84CDmlE0wXZa6YEwhQTg_JoazO--VwVubV9rYq-X7DsB3y3jz0sMEafJpl200LtGrIHJosyhbEVPg=w1920-h1080-s-no
AP1GczMdpDGaOXUShW6FENQ5NSJdP6I_5HPhwjF1f9kQ4Pcn2QNUT0j2vNmlM1tKadBYj10aYPJ81SXjIIAe9MF7Ydw4u6OhbCho74yrm5nks19WApEcyffzo856PhVDoLNkDDfZg1Hn9xgOAGCuhecGzKMehA=w1920-h1080-s-no
Maybe a good one for the trackday people?
nd-photo.nl
4,354
454
The Netherlands
youtube.com
And now on to the good stuff, mounting the bigger downpipe :cheeky:
First some accessories etc
AP1GczMOMZtj18xGMKjC0Euc8ztpOKUXmpxrAmRrlvM79--CICiFOasj1b-ssiMlRMdOqUFhcruS04VxJfGe8G_iw-g6yOYmDwmuM8UYBpfvFCQ-z4wFwpNLqTvrO08itDoe2QyZeL1J1yqoUNKocfpiuK9EKg=w1920-h1080-s-no
New turbo V-band clamp. Partnr: 5Q0253725G
AP1GczOBhXxAVNPI2kjjoRxLKkDs-n18-y8BAol-cGxbxVjiTyf7k77_ib6l5ArnmBWkTPf_Ju0il4EQFl_4jHHmyi0v1QAkTbG5d405q8xjOnxOwUWlqhrV8dA7Ftwn8NcViyrw0eFgFG2TLS8RIBkdzrEFow=w1920-h1080-s-no
New turbo gasket. Partnr: 5Q0253115B
Mine was in good shape, so I re-used and will keep this as a spare
AP1GczO9QDipuQQDYSkEMsrbkdLuo2Xod5okftsAmzmUY3D-cYRxUXeZEaAYlZjHA7KTm27cqXtzwGkLXe7u7_v-J8WDOyCpccLI4vt4kieKFfJJIgHlnYygsXnMvcR6hp_ZKtdcR4AdyhruxnlKZzfwBTow6g=w1920-h1080-s-no
Lambda spacers including a "mini cat". I bought both straight and angled, because I didn't know what I would be using. I used the straight one in the end
AP1GczMXgzoKpaGL2UQqa5Ptk8YHZyLvthOaHRgFRBH1axzs9jAHcQvJKVOu3IjIgf-QZW9vo-HVkAml6j2Cq8w4s28nUegR0WHQitt9rwJ_gQ2BCi0mCJe2bRSEyjgaluOJzrVdda56gYWJwgse8cYPM0cq4Q=w1920-h1080-s-no
The mini cat
AP1GczM_4MqFxUTBMB2gEwUTxlqbVBhxDtskODdFuLsiKAUCqrzKoT1jexb9OpcZ5e0ggAlXz2afqWOaHIvXmK1aFpY-FxakWxeNSF5FzAexH0WegS5dcSWAsrv9lbsBkPYl2Gnwweb8j0udEi-A-YYgVkS2SA=w1920-h1080-s-no
When you screw of the cap, it exposes the cat
AP1GczMZ_ht3dGTHx_S7o-2U1Ll1S2cTsVTtpBIMxddLPuZNQEl0WZL1B5aGVWHaYjpqrtFTttD2ku3O2xBkQ6MJzioI_wIPkMsgwAMVReAJtseOLr27DbfYRllOQg7k_qJwGkPIz_cNBU1-h8YYqpZEHq7Suw=w1920-h1080-s-no
This is how it looks normally
AP1GczNyymisBthHWrX8mva8v_3n9Wc4BaUgwcxPBXna7kwLafEiSlnQi1w9JoViEnkIRAoLl1Aui1YWlt8SUkTSyyzqWf65VUto3bgEdLUh3-U8zC7lvillx7lT9R5JzPZcz5O2zSohI9XflT4Olp7AimZxOg=w1920-h1080-s-no
Also a new exhaust sleeve for connecting the downpipe and catback system. I ended up grinding the old sleeve, as the nut and bolts were simply perished...
AP1GczMhwsQYdOMqNbtuREWSdH1ToOdQevVxOmw8BhupnvHVghD8UOKvCTJk1rqX--7McbaD0YrzlzrUTXEUQWr0JF9nDoTfLSRDRVDEjd4UOqIpqs9CS6eWbz6KwwdHmZojp0gPmvq7qK0FgtGQ5M8HBPipmA=w1920-h1080-s-no
AP1GczOXM1Vw40gzZo2ze2Q-HTxaw4qleMDAYRbJI7wuGaLrafH16AvSnjy5CeTd-X7SoUp4POuYbNAiDTzsSzvgICEKhkOuiNntPvBcHd889tS56WSyrrsKTAyX9h2l_0H0tfVDsALkTv4lmJ0mT5ZM-4PdPw=w1920-h1080-s-no
nd-photo.nl
4,354
454
The Netherlands
youtube.com
Getting the V-band off was easy, and an inspection shows that the IS38 turbo is in great shape. 0 Play on the shaft and no cracks etc
AP1GczP4uJqL4bmBKGE2M82eqKtJ3X9Zjk0h_-oJXYfkZsm1QyexjjUuPwULZAgbP0Qva2aA3O8K_ICSIOvo5DJLYryKGwERaDOcN6-8HhUeTFlFkGwelSi1pelfFctXRzBXFgcVSK8X29wW5L9kF0QM1sn77g=w1920-h1080-s-no
If you are wondering where the metal gasket sits, you can see it clear as day in the picture below. It sits around the turbo outlet
AP1GczP7GRPpGGVltTByYdYkfNXKOkQfSRZ7B_8CRyKSirjDCZ0dDAPR6y-mwpkxlZfNuv-VBJohaVoZSLrIYj2wtYuaEvm7Op_E92V8gUuhxIP2lQ6NnmynElrOWerNBwoi62k-7sUJxMZXu5G6wINcFKzbZA=w685-h1217-s-no
This was the "fun" part. Snaking out the downpipe was pretty annoying and I damaged the heatshield on the firewall a bit, which I will be patching up later
AP1GczPJ8rsbyMsKyNMSP8lLwKF5-qJGdpmwefK3nPGHGgmE6eusGoXBObi_VuWe-z8NbJlAf0jrb6rITauLjojGFZ9JAQQbWiuueOEGBvMD6POt360UtVbSrYRzW3x3T4zfamQhGm0-2xD1gW1oR4jgXOHXLw=w1920-h1080-s-no
AP1GczMUSsLWYIoyjJ1k6NyvhRGS-FnxdTDGyAfXbwp8QD_B28ik2rlZxp1SsFM9nky13BueIVEf5g1JFyOOnDxVy4Piu0zkz_tVMWYLcC9kR4QsumKUVZIHWdIm5BuPaiOxbBz93bqcPY-_JiAzF7THGinG2g=w1920-h1080-s-no
This...
AP1GczNCMWGZwqNp1nwOE78jeznCoQQ3s-zjYTlQU5KOVrl--Tm8_IU_M4S12RAJIco4ji1_3nFIdb3BZwME6-aDO5QzRPobqHugkLBDbiimNsjDBzcUC6mxTFp3TTmdiLBHCS-m804EG_8pG57TIX8JCXHXUQ=w1920-h1080-s-no
nd-photo.nl
4,354
454
The Netherlands
youtube.com
And then the differences become apparent. A smooth transition in the new downpipe instead of a steep corner straight into the cat. Also the cat will sit way lower, so I think the exhaust pulses won't be stacked up directly after the turbo compared to the stock downpipe
AP1GczO4FgQ2I_IlkCqnABLzm82XrYVsx96tWwzX3cebCFufKgwNDExnajqP4LDItCcFIuYeriRMUvNpBHWN4LdoHMr9yIdL90kbI71Q2MIFb-0twwwpsLHMt7Ob56mx1fiskH7530KNBQkxmHWP47Mk4eXmAQ=w1920-h1080-s-no
AP1GczOMw6cn-1n1KHOCKZ0Bkfr0yedceLxmVtYMHGoXVcL9PfCWmLFBi4xm5iF1-lOOZuktp4q9CW1d_QNV1Z9rRLuROWn41nohA4sxE4vhvZIKl-WssH6cWTHevtWWadsB_k5d6YYbKD9bX4Pa2MSPKvCq7A=w1920-h1080-s-no
AP1GczMyPJlXYIGYSiU3fbmmWQEj3wdJC3Fr61crbTBS4RcQXFSkk_AkMRSutbyZ7otIbKXk1-h7qSRzuczLxfFQ4VBiBOU9Y26YArgVWSE_FuRMYSpiRucNfRr8Uk5rC78FW8J5zYkeuL1S-SzSfHNP2wCAKg=w1920-h1080-s-no
nd-photo.nl
4,354
454
The Netherlands
youtube.com
Decided to add the Forge turbo blanket. This is a real pain in the ass to fit, I lost way too much time haha. You will read that everywhere and that is certainly no lie :rofl: Just make sure the wastegate is free to move and you are golden!
Partnr: FMTUBL1
I paid 69 euro, which is a steal. Build quality is great btw!
AP1GczMJI58L9v2HJV4cQb9eF1WKzqyjVcZP3fFHqLGYbOel69CuFQ_XMhkJupZ0hKewjQcpfG9kFS3RSytqC9KI0mAjChTiqOkUa1Lpafhk3zU38olqHewHljfbqyCHS8kkYXlme3dg3gzimWMLIRZNtM9sKA=w1920-h1080-s-no
AP1GczMXS10GP4Uq4HuyO7-3RXnoyzmrwgrV2H1L6g4hrviqLIjdsqBxnY7BIp-1Um0E1inXAE_LPeLM4Yl-DTPJeIgFfEGXd39q6CkK2c0a5PZovohuMKXsutQh53Isw7NZ4YuPQemf3DiqP8o4jUiOtYRjBQ=w1920-h1080-s-no
AP1GczO8yk-IaSlw75KuxsRUVuc4d4_aFR4t001uobSf_XCKVe5PuQE46CxfzK3eO26-3tmL2FM6GXWMcUTqwvudlOanoiRklmJz-Q14I8zIE-Gpkw7IrQ_5RwFsfPY23q3NXLNIZINqOcV90UN9ZC2fkyw9lA=w1920-h1080-s-no
AP1GczMu5Q6tblAnPSQSHcX6L4LwalRDM9kJd8FG1DZsyZPOtDA7gMtZHrZyo5GAw5mqzhyoqMUfjXKaeNzPaZc_0Wb0Fj_wK6o_ULVfYAx6C2xV6duI_o5dVnxyMBsjrbYwY-_hVOkSMuqnBtrr7r_oqE3-Rg=w1920-h1080-s-no
nd-photo.nl
4,354
454
The Netherlands
youtube.com
@Michael_LeonV I think about 2-3 hours. The angle is weird and you have to snake through a piece of the blanket through a tiny space. I used a combination of a tiny grabber and a plastic spatula (be careful not to damage the blanket) to complete this step.
If you succeed in that, you need to connect the 2 pieces together via the click button using 1 hand only, making sure that you apply enough pressure for the button to click in eachother.
As a final step, you connect the spring(s).
[edit]
I filmed the procedure, but takes time to edit etc
nd-photo.nl
4,354
454
The Netherlands
youtube.com
More pictures from the brake disc + pads change. I went for Zimmermann drilled discs + Zimmermann pads. For the rear, I needed to buy different pads, as the pads in the set did not fit.
The discs were the original discs, so there were due for replacement. The pictures speak for themself :cool:
AP1GczN9D8YlOjdQqr_b7b_JiaUEE7a84IVxO59v2KKFdNAkq1yO41_R8U4gSfCCRjVvZK7Pay4qhd1i9OhDSGS2jrpm1b_rGnFS9SJciALI0qotGFlXe0JJwf8goe4AWth2ToEnuo8vLMZXamCVANgYfJpo-Q=w1920-h1080-s-no-gm
AP1GczP5aumiuM6jiqFOARtxaCP0QigPUUg4nl1Q44NEGx0iNOX9_pUwjfxfIfTZ3aDoW2zGum8sB74V0Vsv1K__8QCjheRMjF-v0hKvtm9jztABIE6lOo90GEvyi_FZVLMg52WzBLBsM7sW2x3pZWAXgnjqTg=w1920-h1080-s-no-gm
AP1GczM8484Fp6vGeO8IeaOd3ltezCOZnnUk1ExXgdXhFK0mJto9v8sKR6ad63Pl13qde4wXW9Lo8q6sdBEM1c7yX0KjIVLQZR_X72WXwZawFZ_qC77GYKTcqf72a78vXJi8TgTQBZHtq4d4DSoow-IDQJvJLA=w1920-h1080-s-no-gm
AP1GczOtuHqgpaxpPMQDASctmU_96_O3uERiLWS-h1N-jzEJk3gxhRtU_MrFeiQQ6a5apWWIkD6rRz-bviIpFG6BhJ1ZxYHgRST93hlK-0GA1Y3u7ZdWdd_175vqMmyPftu3Mkyf9DN7I9dQKHJRBGm7j3CnRg=w1920-h1080-s-no-gm
The new Zimmermann pads for the front
AP1GczMdysBHnTfWAot4yHttru8az2VSjUvKRj5SL6KIcC6tldNk_k9Xu6ZvyEWpygzSevaRo-arL1RsgYiu4WhT4YuzMDUbHQ8ZX4vQMJAfYucVoaskOlpM70TFiHODJmnkET6QuIFtMqQlW6evNDI4o91Z1A=w1920-h1080-s-no-gm
AP1GczNfnmyA4okTQt0g9GzA2avaMs4BAaV6r5Hj4wJE3BKgAi9tGFNwlPnZZqn0QXwao-yauqgrbgT36k6UWxKMRjm6t0y9utylws8VZhkOlT6Cz9xR2AWfwX5UlROpXeyGafSviOB0Shn-fYOPxGKE4y6s6A=w1920-h1080-s-no-gm
New sliding pins for the front calipers
AP1GczOyjVKYZeSHKxE9PHbbUpoijGFnF9lyCDfhr24LOb0LrRi0gP_rQJsVMiWh9gE6Zb4hLRMlvinqtjHBCQmTiI9dugJ_Ec2wuxMPXLGYZb2PBwob0v79c9Qs64xSKmOhR8D3fSjAqLaakxbb7e3H7BmUVg=w1920-h1080-s-no-gm
Old brake disc
AP1GczOXckfiMn9gNoDrUIyhQiSeDeunY-rDfJsrsPW3WOQHnkxU3C-TFzfAYcMHCa_fC-PGG_q_gwje7-R4r2yEi0z6AtfZLAb6LBkAxUApVyl6hvuY0vggAsIL-nTo3IeZNzPbf0dBTnZMdSoVVe_4rijNRQ=w1920-h1080-s-no-gm
The old dust shield. I replaced them with new shields, but it seems I forgot to take a picture :ROFLMAO:
AP1GczMs6UZ1TpWvaX4Jdg3Qk9qjNOgSUXJNuIs95iABHGPy3PGv_qQVoOAk7kFzvXMu_SdKzWNSWoa7tJiDBBhpEkHVNNsnGgBHU_KCzUonmtgvFLCvi-iLefOPFzyLB0Y5iKgx7VkAeYasrWQ4WnzdIgmj-g=w1920-h1080-s-no-gm
AP1GczPkXnX6UcO4qWtWULb87niPa8ZNxruSSQ31FIjB-u3N6x5XWNpupRotw6zPkopG4F7kFQyHrd2g0azUg5UAefQZztrY89YBZluu40RdVXzjGeJKGy9BzTfwQAqdFrrqxMOlq1Rsw5WkkU07WfTHbb4yvA=w1920-h1080-s-no-gm
nd-photo.nl
4,354
454
The Netherlands
youtube.com
And pics from the rear axle. I also replaced the dust shields, but it seems there are differences between the 4drive and non-4drive. I bought the 4drive shields and did not want to wait for new shields. So I adjusted them, so they work for my car ;)
AP1GczMdJYtkTffpd9X4f_FFH-mhWmD0oZrXmvr3seU16NdDzoNwFqV5Y6as0eiK5Jm8tPWWieaBFRtGFQtM5FRRhcGFpM1RqEgGQvp9ljN-VLOGyPXpWw9cLpbp2CQJizoF1ndlorGcA9lI2Ol4QV7EqInu5w=w1920-h1080-s-no-gm
AP1GczMU20x2x9oBVwfNJAUIuy3vxgjfcHvOToqvRPiB8orjEV4tJbCB-ggrNEt0wvTWvmo2QccjJZCdS90WA9GMxH5imH6gRM945_qyLc1jdXoz3QsJXyE_PrL_oDTwdB9uqpLdRoxQbR8Kl0G5_uFzutr7Ng=w1920-h1080-s-no-gm
Quite rusty...
AP1GczNNSSRj0pgjaaIQJfGiQGCZh2mCY1f8aTnFJbSlpJIM8vnFyj1JJ9PSo92ijmnEeuEJCuEdqj1qKGxNMYQV7GWbbJmrIJnBSP7AvnejbmEZj5cXiR36WOMIsOP5PmNsKT67XgA3O9dMb0SH341nl7ddeA=w1920-h1080-s-no-gm
Fresh discs always look good, especially when cross-drilled
AP1GczP3oAl8i155pG0uFne0mBOpAS1kPAraBfLExGq8JJq7284UQX7atCK_lSaR1IS4UhDR2YjdTk67ycy9zJl8Cc-Uof3Hm7alyD2BgNGDW1FyF2dcAbI2OPjYa1VoUF1DSOFHnl7Qn9wNSqZ8aVL6IM-W1g=w1920-h1080-s-no-gm
The sorta mangled shields, but you don't really see them so....🤷‍♀️
AP1GczOyyP9Z5SWPgtCg4FCgGe9WdLnoRombTlOJ0FxaMWaw0pVvFh2TgF1hBUo8p9y8fGzJLzWYGIryveda4Okepe2teyUrYJcxDp2ahQIr01FANw-t9h0ulbPylNYs8WTndXOoiBrNiO4AyyGzb_w6Qqu5Kw=w1920-h1080-s-no-gm
Rear brackets with new hardware added
AP1GczMNcajWOakwYO7zfQPB50J4__Vo7oer5A5vzbcgzxGWKxY1RSg7kfAYuqDU7mIREuSySZsb1Fk6DNJ5gf61nGET1Xc5H5kPIhcRFP24p4xj5ZiL9EDhBV9djyQ1ETbDLy-m5_nIWWBx1pHCIMvhCsCDXg=w1920-h1080-s-no-gm
The old rear pads
AP1GczM3QcqPNrCTtSp5LWOgSpb57wAoPh6j4hDMJwvV4FHw9iyaej4PvqifsnoKiWL3JWKUwcv6tDCuAUuOkmfKcrje9hccgj_malmH69QcnRmNv2zIL911RLhqlGOQPhu_ECuPtLo4uW5YNihMta9lILwVYQ=w1920-h1080-s-no-gm
Looks way better! The rear calipers need a little touchup, something for later in the year
AP1GczOyJcDX8ML01_DPTiHcF9b-71Rduzlhuf2esD0rmQdA_bdAbdG3-LKB-DPzWqGg_aXt39vYILJFNUTguKcvNBnLz3Dw8zPpuXYf3KWnigAG2yQfqN9R2qRpx16UXkpIP5KZHdtAYOUVg95WJhGDB1MKVA=w1920-h1080-s-no-gm
AP1GczOp9t9tPKPZ6ClWa3ZL-CxT_JFAytgGvjmLh49frcWslWpRY23tZ_jfLhqG3vvoOvkKJqSGQ9hr6qvnbCgpewwiFrt_YPrBv2nG3JORmL_-4a0ezzMLULGEUgUF71swf_qfO96B6LkbPIfpY51DFFQHPQ=w1920-h1080-s-no-gm
