ND-Photo.nl 's - Seat Leon ST Cupra 280
tracktoy
815
662
Bought the Audi RS3 8V brake ducts / deflectors. They are by no means a straight fit and you need to hack away most of the material. I still need to fit them, as I have other priorities.
Partnr : 8V0407811 / 8V0407812
I have to say (and it was a very long time ago) I fitted them when I had stock wishbone mount they fitted with no problems but mine is a 2014 model so maybe they changed something.
I did notice on my parts supplier that I need a different set of ducts when I replaced the wishbones with the Super Pro ones, but actually it was the same duct and just needed brute force to fit.
tracktoy
815
662
Ah ok, when I first fitted these I had already had the KW DDC Plug and Play suspension (now replaced) and the garage re-positioned the height sensor so guess that is why I did not have any issues.
nd-photo.nl
4,432
505
The Netherlands
youtube.com
Another modification I can highly recommend, replacing the 4 negative terminals for the coil packs with a single wire harness. This is connected to the big negative terminal behind the battery.
This will get rid of the clunky way of removing the coil packs and the chance of snapping these wires off everytime you take the coil packs out
AP1GczNqHFYShWHzz0j2WHHABFTwidh4ay_WBdnGDpwDUajEMJcEXXU6vXx6P46IS-vU10Ydd5JglgjDR22oGZzvcvPPSEgsTKl7MV113jbdN02BKZDMKYcF9Z9o6n4SR8hQpEHF3SsYTNOP7GX4KqyaUIAwlQ=w1920-h1080-s-no-gm
AP1GczN1wv0n2ZjshcilNT0Im-eSCzccCZCtopujcow7G1fiffsRgIUkqdDM6QPfc05InsBa2p2X8izn8qex3E2hZZStd79AGVBjEUGxzEw1ZUmfl9ny3V3W62u7LIUTcvd16_QMN5bTOUpYJTDOH3KJe7Uogw=w1920-h1080-s-no-gm
As you can see, one of the terminals was already bent big time...
AP1GczMWMFT03_K9LkffudEj7bIhEq-6V_6act6AsAXxaq3g_VMFb65d3sFDxOloS_9sZPEE5OgkqVyxzMEP31FARUGB1l-x3-9FzkMk0QY1N55AewxdLyP5OFdMtFposHT7Dhgyim9kdcnAtsQXFCikflkn9g=w1920-h1080-s-no-gm
Modified the blue harness with some black felt tape for the OE look (y)
AP1GczO004piJey0PV70ERafP4VXJIfmr1R9E4jYukuMaX3bWdgUWiJyk7CCLd9Mh1ky2e3REYVgvo9Wa5DiFK0maOa3A5w3O8BCr0WtCwypKzpe8x3H74Pi_zYOPY4WK1JenznO71L2VBF3yXu_UOyD8aIXSg=w1920-h1080-s-no-gm
Reactions: Mo_86
nd-photo.nl
4,432
505
The Netherlands
youtube.com
I wanted to try out bronze wheels for some time now and I got lucky with these MM MM-06 wheels in 19 inch with Nexen SU1 tyres (as good as new, 7mm thread, DOT code from 2023). Fitment is 100%!
I will be replacing the tyres probably next year, as I dont like the "slim" look, I prefer when the sidewalls are vertical so to speak
AP1GczMuHFlIrCiR8MlnX2uyqFj7KdxwFqKEkZ1dhHPAX3AQNYvNYDrc7nGO63LKHgSm-RkV0YGqxeVJIxFYicKEwJmgnpSe3ySd-kOsPe5kQcNBZ8mtIQ2F7FO9RyqGfup9MHouMktlC-Sv64xAePaEK3YhfQ=w1920-h1080-s-no-gm
AP1GczNfjcdFihIUJMIqxWP0e0bkjdo0wOhpCTg9tWLkLRzbW_BYG1_3tUvisn7Gp0KlVTCWfZ20rz7VFB-IXYYf7-B4BERO0WEQCk8g0JYWAlKWJ_KB7Sq5XdlAvAeZiCs_HnGzbHHMEiBfRgliFTgvgekhsg=w1920-h1080-s-no-gm
The ST has enough space to transport them easily :)
AP1GczNmeJkknun32Q9Ek9RVTbq-PA4AEqNOT-rg2VS7sQIX-sUHqBb-IpMmEyoeRtVirwuA70mPZbDH6vuzSm-F15S96QFw229VsuEHgqsDv2d9BocdsC2MjiXw9h_JdnEfKKOxpmcNM102oyujAN0ZWc1loQ=w1920-h1080-s-no-gm
AP1GczOSqV1A1JsrvMIXP7jeXeiPWsAvbAjRyPBcZrc672Fl_ov-X_Uw0O_6RomW3BM1lb14zhh4_CJcgMxeJaXpOtviAiRGFuVEL3staJpi1NnM0BEfYDvRwFEsPkq6yUJoCAXxvJ_t4pkrGSfGVr1SztaX5w=w1920-h1080-s-no-gm
I like them...a lot :love:
AP1GczM2a__5zElzc6jznhElGW64JsV45loIkCzNUT06CI-gzz3OyoT0-xrNfJmoL9sZfVIhzuiIfQgs5uwwbUoB_N-fdnSb8V3-LKD5P2xxPycjqrEAI3l3Yovywh2shGCQVNxtspEakr5mzLqkXUTXLlwaqQ=w1920-h1080-s-no-gm
Reactions: Mo_86
nd-photo.nl
4,432
505
The Netherlands
youtube.com
Seems I forgot to post the pictures, but I mentioned it once in my thread. The mod known as the Pikey R600 mod. I was going back and forwards with this, but in the end I kept it.
Partnr: 5Q0129849
And you need 2 screws, I already had these lying around (bought a 100 pack or something from Aliexpress)
AP1GczMngWxbKi3ikDv3TJLoojNAQT0tbeM7i69rmYvHpB8FXOMe-e15D_ht6L0QiqJBI_6kGgjc5sfl864TjUj4Zo3iEieEl08FNOvXZkXOzZOOEF1Oc8MIv66LXbPav3nIblZ0jTj5T2tYjjF5bhgPyqtY-g=w1920-h1080-s-no-gm
AP1GczMpFKmpbOvQQd96uSrP1ZXY2eyKqDTLg-WUbt-ec-cymBytJ99sxIJ3RJAcbp4eTmfyQl3ziH25pR7DEdQ_Nut1XmEzz_N6udAchV1KPdgr-xThJpX_PN81MCSnSsG35Xruy5-t8sBCly-bvyQ0oXI3sQ=w1920-h1080-s-no-gm
Supposedly this fits in here ;)
AP1GczP6J2XSznEa3PhfSvsRF_qK_lTNxqw5tu8Nr0FbpDqjFfH_qMiRKAMNmr1vY3KWSkbg38Acjc1EeVGxn_ZshDOt9cJUn_lwvtsy05It5emWu0N2NDZrwh81sZ4fYT3eaYXzEPzZQUFQvP1lAGCjQw7e6A=w1920-h1080-s-no-gm
Zoomed out
AP1GczNtf7jH3R6GISeU69wbUE0mob0OvQQGbbgjyegLA2fW9qx9ZivRRa3oe6o_0dvIBRVkGPEtcwX4iabxx9ggpsf0_K6l0SaHJeXaFN4pHC0M96cpjFsIY8RLHTY-cBDjEna2yHlpcdaSMf0QCJUAaaDQJg=w1920-h1080-s-no-gm
Looking good already!
AP1GczNyLW8QwdQLkVAAEQTXDrsRqgb3Kjyf8bYemcLNDCpJHn393aM_oG8yob97_gJ46shDD4jX22p9UaBIi1MNwRMgfs-99vKptVtAmTaANNqHwOzsD3zccON_lpqUeOuvM4-SmGHohm1qF_9UpTHzsx1N9g=w1920-h1080-s-no-gm
You have to drill 2 small holes for the screws. Not essential, but I added them for peace of mind
AP1GczOJ4VsTad4KbKGvskpBLsbp2hYKogOm9Cb_nI4Fk-7FV3rcsjXrA6QDblhkL6_iHYL0iTxy8jOtqDKoMFpla2i-s80vIZyCpHKNT71AMHGiUhLHj9xXj-TeDXWexG0wzKlfMdILdfP6WHkHrd9dEKkPVg=w1920-h1080-s-no-gm
Another look at the screws
AP1GczNAachfRX0UnOdz7IQ-Mg-hf2KdtDGKURa0-DiAagSyJbRm7lha5OBV9Za0JWXh9ft3Ge_oTGT9RtCDIVv4qOpERJ8opr4A7AfB_48I2zxXYB9ipUsXOcxSLA2OivGSVC80Rwr5A1TShOfbfqLcefJ-bQ=w1920-h1080-s-no-gm
AP1GczOAuZcM62L9SflRmKr_PTNnvLZtEvvQSJSlf_u9I1PaN5VXgmATEBeyVGqzcoJuufOjJiaMzyUGUAPIVHBTRyekqN8bvH8AGGlUM8t4KYV-phxWw9RARddew3gnIQl8Jcur7kUDQEPV89L25NE3-VbBdg=w1920-h1080-s-no-gm
Michael_LeonV
69
27
Partnr: 5Q0129849
For the uninitiated, what does this achieve ?
Reactions: nd-photo.nl
TripleBob
379
278
From the factory the air intake feeds half the air collected into/over the engine bay, and the other half is fed into the airbox/turbo. With this mod the engine bay feed is blanked off, so 100% of the air is fed into the turbo. This equals more and less turbulent air = potentially more power
Worth noting that some of the VW performance variants have this ‘mod’ already in situ from the factory
nd-photo.nl
4,432
505
The Netherlands
youtube.com
I was totally wrong it seems haha. I talked to a guy with an Audi S3 (also MQB off course) and I was able to look under his car and he showed me how they clicked into place. I just needed some brute force to click them into the right place and then tighten the tyraps.
As I brutally mangled the driver side one, I ordered a new one which I will be placing soon :lol:
Reactions: tracktoy
nd-photo.nl
4,432
505
The Netherlands
youtube.com
@TripleBob explained it already, but "R600" refers to the Racingline R600 intake (see pic below)
Reactions: TripleBob
tracktoy
815
662
Every day is a school day, and as I am old my memory can forget what I did in the past.
Keep up the good work your motor is great and getting better.
Michael_LeonV
69
27
Cheers. Aside from the price (eyewatering is the term I use), the real issue that I have found is that whilst there is plenty of stuff available for the 2024 Leon, it focuses only on the VZ/VZx variants (i.e not the 190hp DNNA powered V variants), so ANY potential mods are really dubious/unknown whether they will fit :mad:
[sigh]
nd-photo.nl
4,432
505
The Netherlands
youtube.com
@tracktoy I appreciate it man. I could not help myself and went for some optimization in the form of a Stage 1+ tune and stage 2 DSG tune not too long ago. The difference is crazy to say the least :eek:
I was surprised I was almost pushing 300HP already o_O Decat downpipe will do that said the tuner
AP1GczPIOo-QxkMG_MjLpyKj0gLFWhk-SqL6ibpVrVlx768pIqLgL2K4U9uAoO23oxEZWVXx7Irff4DC6aPlcUDswqiOfl6jvaE1SGlDX17Pbs2q6aQ8E3RXZnsiNmMaHCfo9F1cNVib2KXyW3qjDWBrlrGbRQ=w682-h1213-s-no-gm
@Michael_LeonV sucks that they mainly focus on the performance variants. I dont know how return policy is in your country, but maybe try some things here and there and return it if it doesn't fit?
In the meantime I also invested in a expensive intake, but I think its worth it...:love:
Michael_LeonV
69
27
Return postage would be a killer !!!
got the JB4 fitted last night. What a faff with the undertray to get to the TMAP sensor !!!
