Leon 2021 PHEV DashCam/Fuses help!
Jun 16, 2025
Hoping to get a quick bit of advice on hard-wiring a dashcam & which fuses to connect to for parking mode to work? Have two connecters (red & black) and an earth... sadly it's not so easy to get a Haynes manual!
MJ
5,617
54
Manchester
The fuses labelled in red are permanently live, those in green are ignition live only.
Jun 16, 2025
Ah, thank you. Couple further questions if I may. Do I have to use a slot that's already occupied, or better an empty? Second question... how on earth do I disconnect the car battery? I'm guessing I should do that first!
MJ
5,617
54
Manchester
Personally I'd use an unoccupied slot that has a supply pin in it. I don't see the need to disconnect the battery if you're only wiring in a dash cam.
Jun 16, 2025
Thank you... ended up splashing the cash a little, it got a bit sparky when I tried so backed off rapidly. No damage done though. Were a couple other bits I was a little stuck on, but thank you for the advice.
Moving from a 25 year old car to a 3 year old car... quite some learning curve, especially with the electrics. I'm sure I'll have bundles of more questions as I get more familier!
