Model Year 24/25 Surprised by road noise (2024 Formentor V2 facelift)
Jun 22, 2025
7
Hi All. I recently bought a 74 plate Formentor V2 and I'm surprised at how loud it is when driving on normal roads.
I have the 1.5 eTSI with Pirelli P Zero tyres. There is no engine top cover - I was told was removed due to fire risk recall. There is no sound deadening under the the bonnet. When driving at 60 on a half-decent UK road surface (which is hard to find !) the road noise is much louder than my last car (1.5 TSI Skoda Karoq).
I was considering using some adhesive backed acoustic sound deadening sheets, but I am worried the adhesive will deteriorate due to heat from the engine.
I'd very much welcome any views or solutions you may have used, if you've encountered similar.
Cheers, and thanks in advance for any tips.
CupForm
166
86
Bucharest, RO
I'm a bit puzzled... The topic title and also in your description you mention "Road noise" - so why would you worry about the sound deadening under the bonnet? Most of the road noise comes directly from the tires, especially since Cupra installed plastic protections under the front wheel arches - not at all useful in soundproofing.
Also, the 1.5 TSI engine on the facelift model has no engine cover by design - it was not removed due to fire risk recall (that's an old story regarding only the 2.0 TSI engines of the pre-facelift). The facelift 1.5 TSI has a ridiculously-small plastic cover surrounding the oil-cap.
Some owners use the adhesive sound deadening sheets directly under the wheel arches to reduce the road noise. See posts/pictures in the link from our fellow-Octavians:
Jun 22, 2025
7
Thank you regarding the wheel arch sound deadening. I'll give it a go.
Reactions: CupForm
Jun 22, 2025
7
Reactions: CupForm
Bahnstormer_vRS
67
28
I've got Pirelli PZero PZ4s on my Ateca VZ2.
They're on the noisy side, very much road surface dependant, especially compared to previous Bridgestone T005s.
What tyre pressures do you run?
The Ateca has normal and (lower) comfort. The comfort is quieter and not especially soft in the scheme of things.
Guy
Sent from my Galaxy S23 Ultra using Tapatalk
Jun 22, 2025
7
Guy
Currently running tyres at 36psi all round, which is the recommended settings. I was very close to getting an Ateca to replace my Karoq - lovely car.
Reactions: Bahnstormer_vRS
Bahnstormer_vRS
67
28
Might be worth checking the tyre pressures in the book / door pillar label to see whether your on normal or comfort.
Karoq and Ateca are sister models; both built by Skoda in the Czech Republic. 😉 😉
Having owned Skodas for 15 years, I was perfectly happy to switch to an Ateca.
Guy
