Clicking sound out of dash when AC cooling is on for a longer period
Frostensen
117
7
So, as the title says, when my AC is cooling the car, after a certain while a clicking noise starts coming out of the dash. It's constant until I turn off the AC. It happens only when the cooling is on (no problems with heating). It's really annoying. Does anyone have an idea what that could possibly be?
Click Clack sound
Frostensen
117
7
Have you pulled fault codes? That might give some idea, there might be a stored code that can help identify what the problem is.
No fault codes that I can relate to the problem. I have these, but I don't think they are connected to the issue
Trouble codes:
00576 - Terminal 15 Electrical error in circuit
Intermittent
00883 - Ignition/starter switch (terminal S) Electrical error in circuit
Intermittent
00884 - Ignition/starter switch (terminal X) Electrical error in circuit
Intermittent
01744 - Ignition/Starter Switch D (terminal P) Electrical error in circuit
Intermittent
00885 - Ignition/starter switch (terminal 50) Electrical error in circuit
Intermittent
R3k1355
1,878
280
Yorkshire
The only other easy thing might be something stuck in the ducts or in the motor, maybe pop the motor and pollen filter out and see if there's any crap in there?
Otherwise you might be pulling the dash apart to inspect everything
Reactions: Frostensen
Frostensen
117
7
I think it's the pulling dash apart option... :cry:
