Sep 2, 2025
Hi Guys,
looking for some advice, been getting an arror message "Oil sensor faulty visit workshop". Plugged in to see if any codes would come up but nothing on the scanner. Swapped out the oil level sensor and still have the same issue. Also taken the car to a mechanic and he couldn't find any stored error codes but the light is still coming of with an error message. Does anyone know what this could be or had the problem themselves? Is it more likely a harness issue.
my car is a 2019 plate Seat Ibiza FR sport 1.0ltr 115hp
A strange situation if you are getting the car reporting a problem, but your scan tool and a garage's scan tool could not find any relevant stored fault codes.
Are either of you using scan tools that are fully compliant with VW Group cars?
I'm assuming the garage has a fully compliant scanner, it also look like a fairly standard error so its a bit strange to not show up.
It does only flash up for a few seconds then dissappear.
Hi Guys,
hola amigo
finalmente que hiciste?
tengo el mismo problema en un t cross con el mismo motor, tras un cambio de aceite me saltó el mensaje.. he cambiado 2 sensores de aceite nuevos y sigue el mismo problema... y sigo gastando dinero
hey buddy finally what did you do? I have the same problem on a T Cross with the same engine, after an oil change the message came out.. I have changed 2 new oil sensors and the same problem remains... And I keep spending money
