Although I don’t have wrap-around ambient lighting, what about this LED strip at the top of the door trim above the door handle? Is there actually an LED strip there, and is it possible to activate it via OBD rather than with an FEC or SWaP code?”
I have the Xcellence level myself and I'm also interested in whether the LED strip above the door can be made to light up or change colors. I mean, the one above the door looks like it has a strip. In Finland, that package includes blind spot warning, etc. if you have a full Ambilight package.
Thanks mate. Just went through your screenshots and did coding on obdeleven and now I can change colors. From only red and white to more than 10 colors and ability to change them...this is awesome
I have a 2022 year Xcellence and I set those values via obdelev. I got those colors to appear and also the different ambilight modes, but I can't change the colors, only the white color is on. If I try different modes, I get the lights off completely. Did I miss something or i don't have RGB LEDs?
Hi, I have a V1 Cupra, changing the LEDs on the doors would be amazing.
It's as simple as buying odbeleven and inputting some codes?
I also have questions about the LED strips, from what I understand, the wraparound dash strip cannot be done but it does look like the door strips are probably fitted already.
Thanks in advance!
