Jul 8, 2025
Hi guys,
First ever Seat and love it but it I’ve got a problem already.
I purchased a Seat Leon FR Sport back in May. This is a 74 plate reg. Since having the car, I’ve noticed, now 6 or 7 times, that the engine cuts out while driving at low speeds when approaching, or pulling away from roundabouts and junctions. It isn’t a typical stall as the car already tends to be slowly moving. The dash eventually then tells me to ‘manually restart the engine’. To start with, thought it was me!
I’ve had it back at my local dealership. The car was looked over and the computer checked for errors. No fault codes were found. They also said the Seat technicians were unable to replicate the fault. I was told that they had seen similar issues before with the cars but no obvious fault was found. Has anyone heard of this?
Last week, the car stalled at low speed as I was going round a mini-roundabout. The car didn’t need to come to a complete stop at the junction. I lost all power and it took me two attempts to get the car restarted. This was dangerous and I was limping around the mini roundabout with traffic coming. I had to pull over as soon as I could to get the car restarted.
After the visit to the dealership, I am at a loss because they can’t carry out a repair as no fault is being shown but there clearly is a problem here.
I’ve been manually disabling the start/stop assist at the start of every journey to see if this helps. However, today, the start/stop was disabled and the engine cut out again after I had switched from second to first gear. I was promoted with the same message: ‘manually restart engine’. This was while approaching traffic lights which were red.
Thanks in advance! ?
Hi and Welcome to the community! That must be frustrating. Worth checking our Leon forum to see if anyone has had similar issues. Hope you get it sorted.
Cheers,
Scott
I experienced a similar issue today, I have the 2025 fr back edition 150psi petrol manual. Was changing lanes and went to accelerate and nothing happened. Felt like stop start but was moving to quickly, around 15 to 20 mph.
This is going to sound weird, but check if the PCV valve/hoses are clogged. I had a similar issue with the VW Lupo from my girlfriend, which had intermittent power cuts due to clogging of this system.
Other things worth checking
- Health of the battery (does it hold its charge? and how much charge)
- Health of the alternator (does it charge with 14v)
- Random cuts and not being able to start also points to crank position sensor
- Does it happen with low fuel in the tank, or also with full tank?
Oil separator on the VW Lupo
And what came out of it...
Reactions: digitaria
I'm just read d_drive1 post, and wondered whether the engine cutting out at low speeds has now been resolved, and more importantly how it was rectified. I work at a SEAT dealer and have a customer with a similar issue, again no faults were logged so very difficult to diagnose. If you are able to come back to me, that'll be appreciated. Kind Regards.
Reactions: nd-photo.nl
I'm sure there was another thread where someone else had the same issue too.
Our manual ATECA 1.5 TSI will sometimes stall, or try to stall, if for example slowing to turn into another road but not carrying enough speed in second gear so when the clutch is lifted it stutters unless you get the revs up quickly.
Hi, afraid no further forward on this one. That said, it hasn’t done it for weeks. I’m at a bit of a loss as it’s very intermittent and I can’t get anywhere at the dealer as they can’t find a fault either.
This is very similar to me and the same thing happened to me changing from 4th to 3rd as I approached a roundabout.
Had contact from the garage/dealer and they have managed to experience the fault on our FR, as such now waiting for further investigation/diagnostics, will add updates as they come as I know how frustrating this is for the OP and others affected.
Reactions: Syphon
A quick update, we have our FR back now, the dealer managed to experience the fault, and we believe they have pinpointed it. We now have the car back and are reasonably confident (or at least as much as you can be with intermittent faults) this has been resolved. Now i am by no means tecnical, but the over all jist is a wiring loom had become displaced/ moved more than it should too closely to the alternator, generating a charge and causing a surge or something along those lines causing the car to cut out. Hope this helps with others having similar concerns, our dealer have been top draw in persisting on this for us, and hope this is the end of this one.
Reactions: Loadmaster748
Hi, please could you message me and tell me the outcome to this problem.. as we have the same issue. Thank you
Hi guys,
Please can you help.. we have the same problem with our Seat Leon 25 plate. The dealer is saying they can’t find anything on the diagnostics. We have told them others have had this problem, however they have said could you get the chassis number off someone like yourself so they can check it out. Sorry to bother you but so frustrated with this car. Thank you
Chassis number, in other words the VIN?
And the dealer is asking you to find it for them? The dealer knows where it is and besides, they only need your registration to cross check it as well.
PC1860* is asking for the VIN from elrolzio's vehicle.
With the VIN of the rectified vehicle, the other dealer can check what repair was carried out on the now fixed vehicle and try it for themselves on the faulty vehicle.
Without the basic vehicle details (reg/vin) the dealer can't look into it further.
Reactions: Syphon
Thank you for your message.
Talks with the dealership are ongoing.
Reactions: Syphon
Doh! I've re-read the post!
Thanks.
Hi there,
I’ve just bought a brand new 75 plate Cupra Formentor 1.5tsi petrol/manual and am having the exact same issue.
In the few weeks I’ve had it, it must have cut out at least 10 times at roundabouts/Junctions.
I’ve owned Seats for 15 years so have tried all the different variations of drive assists etc, and it’s still doing it.
Just randomly cuts out and says ‘engine needs to be started manually’.
Obviously this is ridiculous dangerous as fear I’ll end up getting rear ended.
I am going to contact Cupra this week but thought I’d ask on here first so I had at least some information to give them if someone has managed to get it solved.
TIA.
