Nov 18, 2025
Hi, i have a Leon MK3 SC FR 150hp CRMB engine 10/2015 reg and since my shocks (+ the strut mounts and the sway bar links) were replaced 3000 km ago i am planning on slapping some lowering springs, from what i have seen my car has Axle load 1 990kg and axle load 2 870kg, i would assume 1 being front and 2 being rear, and the rear suspension setup is torsion beam, so there is no H&R kit that has both front axle load 990kg+ and made for torsion beam rear axle, only 990kg+ for multi link or 930kg max axle load for torsion beam, so i was wondering if the eibach sportline on the FR model it really is a 45mm drop on the front and 40mm on the rear, or the FR model is slightly lower from factory and the real lowering values are less, on the websites i found they say the 40mm on the rear and 45mm on the front are from the base model, same thing with the pro-kit that lowers 30mm both front and back, they say in the FR model the lowering values can be less, and i want more than 25mm drop but less than 40/45mm, can anyone clarify these doubts I have regarding about the real drop in height on an FR model
Reactions: AlperUtkuCeylan
I have eibach pro-kit on my ST (SE not FR) with torsion beam rear. Is the perfect lowering amount for me, feels perfect and even lowering front and back
You got any before and afters pics of your ST. Can't see it being much of a difference between the SE & FR?? I am torn between the Sportline Kit & the Pro Kit.
