oDx_Vortex
22
my sound system in my seat Leon fr 2017 3 door is ok, i want to know if i can upgrade my speakers easy and cheap to make it sound better. many thanks
Have you looked at fitting some sound proofing material/s in the doors as well as the rear sides? This should help improve the sound from the existing system before you spend ££'s on new speakers.
Depending upon where you are located a car audio specialist who installs systems should be able to help or failing that try Google and speak to one or two.
HTH
Reactions: AlperUtkuCeylan
Thank you for your reply gary, In my previous car i had bose speakers from factory and when i got my seat i miss my old sound system so i wanna know if i can install bose or similar brands in my car. Many thanks
Reactions: Gary18
I suspect some Focal speakers would fit but it's best to check with an audio specialist. Make sure you get some covers for your new speakers to protect them from any water that may find its way into the inside of the doors.
Focal ISU200 will fit in the front doors with adaptor rings.
Focal ISU165 will fit in the rear with adaptor rings.
Sound is better than stock.
You could then have SEAT SOUND parts installed ( rear sub & dash speaker ) - and have the main unit re-programmed to activate it.
Reactions: Gary18
How do i do that, also what sort of adapter rings, im not really goos at this stuff,
Not sure what is available to you in Netherlands - but in UK I just googled speaker adapter rings for seat Leon 5F and many came up from local suppliers or on ebay.
easy, cheap and better rarely go together! ;)
I have a huge kicker 4x amp and lovely MB Quart components & sub sitting in my garage - which I have been toying on fitting - but the standard set up sounds quite decent I haven't really needed to (I don't have seat sound).
The Leon has big 8" door speakers, and tweaking the bass up a smidge on the EQ really sounds good to my ears - and I do like nice sounding music, having some nice Ruark home speakers.
I would add, bluetooth music from my phone sounds much better than the DAB radio.
Surely in the case of internet radio players from your phone vs DAB radio is going to depend on how good the phone signal is whilst driving?
I was referring to a music streaming service like youtube music or spotify from my phone - rather than an internet radio app.
But yes - you would need a mobile signal!
yeah i use apple car play. its just going from really nice Bose speakers to standard. the standard sound is nice but once you experience a nice sound system its hard to go back
