MK R BOY
168
11
Hi All
My LCR has pulled a brake line advisories on its last MOT, I thought it would be pretty easy to source even a standard OEM to be honest but I'm struggling.
I need the rear nearside brake line, its not the short one from the caliper, but the straightish one that runs the side skirt, part NO is 1JO 614 741 AC I believe.
Any help is appreciated.
Rgds
I have the brake lines for the rear beam but I dont keep any of the hardlines from under the car.
I purchased new ones from the TPS several years ago and they were surprisingly cheap.
Probably discontinued now though.
Time to whip out the brake flaring tool and make your own lines.
Sent from my SM-S906B using Tapatalk
Is your description "brake pipes corroded, or covered with grease,or other material"?
If so, no need to do anything. Any decent garage will just clean them up and regrease them automatically for you. I've had that as an annual advisory for about 5 years.
Yes that's the advisory.
If being covered in grease is an issue, then why regrease them?
Out of interest, do we know if this part is identical on the golf Mark IV? if so is the part number the same?
Yeah, it's a daft description. To stop them corroding any more they need regreasing every year. The old grease gunks up and attracts dirt, so it needs scraping off and new putting on.
