Dec 22, 2025
Hi all,
I've got a 2025 Ibiza I've just bought (cat s repaired), done a couple hundred miles in it no problem at all.
Left home the other day and after about 5 minutes the dashboard lit up with all the warning lights it could and got fault messages for practically every sensor in the car. Tyre pressure, parking sensors, auto lights, front assist, ecs etc. Almost like the ECU lost connection with everything.
Also found that the engine was almost "pulsing" when idle, though I'm assuming that's just a symptom of it losing all the sensors.
I've let the car sit overnight but it throws up all the errors again as soon as I turn the ignition on.
Anyone have any initial ideas I can try before I go ahead and buy an OBDEleven to read the fault codes?
Sorry I should have added a few more words. The 2025 Ibiza ECU is protected by SFD2. I don't use OBD11 but I do not think it is SFD2 compatible. Wouldn't want the op to shed out money only to find it doesn't work. Others on the site who use it will know or check with OBD11 direct.
If he's only buying it to read the fault memory of each control unit then he should have avoided the need to unlock any modules protected by SFD.
Having the bonnet open is usually enough to deactivate the diagnostic firewall for fault diagnosis, attempted alterations to the coding or dataset will require SFD unlocking.
SFD2 isn’t touched for simple diagnostic scans
Open the bonnet
Disable the diagnostic firewall in the diagnostic gateway (SFD1)
Crack on as usual
Reactions: tracktoy
