Sonab
Hi,
Recently I have bought Cupra Formentor 2025 Facelift.
I have noticed that power windows doesn't work up direction after i roll them down completely.
But if i roll them down manually (not all the way down) then the power window roll up and everything works.
This issue happens only on the front doors.
Back doors power window and manually works fine.
I have tried reset the power switch, but it doesn't help or i did it wrong. It seems like when the window get to the down point it stuck the module.
One more question,
The windows doesn't go all the way down on all four doors, is it commmon on Formentor?
Thanks.
I have similar issues on my 2025 formentor, but for me they will open sometimes if I try to close them. Also only effects windows on front doors, also happens sometimes when using comfort windows function from my key. I booked a repair at my dealer, will update when I get more info
Same car here (2025 Cupra Formentor VZ) and I’m seeing the same thing: sometimes when I pull up to close the driver’s window it suddenly goes down or reverses near the top like the anti‑pinch is overreacting, even though nothing is in the way.
Same issue on my 2025 Formentor VZ, gf tried to roll down the window on passager side which worked fine but then when rolling it back up it malfunctioned and still went down. Any news @petrolhead_uk ?
my dealer took in my car for a day and said they fixed it by calibrating the sensors
the issue still persists for me tho and now I have an error on one of the doors
Code:
B148754 - Motor for window regulator - No basic setting
I will book another visit after the holidays and update you guys when I know more
Out of curiosity, what version of software do you chaps have on your infotainment systems?
2650
2768 is available via the PV4 update suite, that could well resolve the window issue.
Reactions: trew
My car is currently running on update 2632 and has none of the window issues described in the thread (touch wood). The people reporting these issues seem to be running on a later(?) OTA update (2650). Does this mean that update 2650 has CAUSED the issue - or am I barking up the wrong tree?
...or do they issue different updates for different variants of the same model (I presume they do)?
That's possible. I wish if Cupra/Seat/WV would provide release notes for each update. It would help us troubleshoot these issue
Reactions: trew
Same issue on my Cupra Leon ST 2025..when I want to close the front windows even if its not fully down, it goes down..
SW version: 2650
