Happy Ant
70
16
Hi
I wonder if anybody can advice me please. I want to fit a dash cam to my new car, however rather than hardwire it into the system I was told an OBD2 cable would work without draining the car battery, when the camera is in parked mode.
My question:- Is it simple to access the OBD panel and connect the cable into the system please?
Leon 1.5 eTSI FR automatic
Which fuse box?
And doesn't that need somebody who knows what they are doing with the fuse box?
You'll need to plug your fuse tap into one of the vacant slots marked "15+".
Thanks but its too technical for me, basic DIY yes anything else I leave to the experts So I will not interfere with the fuse boxes but will speak to my dealer about fitting the dash cam for me, its much safer lol
I'm running a Vantrue N4pro since a few years, their fuse box kit was pretty easy to install and most important it has a relay that can switch off the dash cams if car battery voltage gets low or cams stay active more than a set time.
So even if you go to your dealer and get a different model, I suggest you make them use a fuse box kit.
