Decided to get the Cupra mapped in July 2025. Went to a smaller company called Performance Base, which is located 20 minutes from me. He was recommended to me by some people I know.
I didnt want anything extreme and went for a Stage 1+ map combined with a Stage 2 DSG map.
Results:
296 BHP > 381 BHP
378Nm > 524Nm
He mentioned that the bigger downpipe resulted in the horsepower bump to almost 300 BHP in stock form (y) It'scrazy how a bit of adjustments in the software can result in such big changes :rock:
Getting the Cupra ready
AP1GczPnWlB1UGELw7EK5odlTmxYLOhMAASWK6XiJs_U8lh-nbySAFbp2BkwuYPw8gRFRBz1Se_dxRAPVfvNiiEOVpkx7iTRSTYZSoDfFEl2TOiQmVlAc-RjgNhdG-gUC8s1UOYLlYPwy3a_9_967RKXrUywBw=w720-h1280-s-no
His mapped Audi S3 limousine in front (about 420 BHP)
AP1GczP0CFOi65lETPbJcG0Qc7xn0zzOxWTzSvDEnFSa_NqK15KKEc1kokwWl__JkJIRDCbkicKImp3CZSWPc2VqFa1bp0qdVEuJfzKNTg62QADsqqPA84MFJxNWMh5fWtt6Cg_nX02vRVHO1Ktv2gKEgxcE6Q=w720-h1280-s-no
He uses DynoPro, so the car is tuned on the streets. This device on your wheel bolt is combined with OBD data to get to the results
AP1GczOjcNcUDoTWfBW0FypIUvMTT8Q1xeUzCOZJRGc3jnWEQXYtuRrdDx_iKA3MKZZ5xc9Xo_-pfsmZ9Ax9bmLA9QDsUGzqM0p0J9UHzyZAtCqwxASd46sd09bOoFtbEJForaZ8v_GBEb0TXI_xZkhwqpDw2w=w720-h1280-s-no
He noticed that there was some irratic behaviour sometimes and asked which plugs I used (Bosch). I was recommended these NGK plugs, which I ordered off course.
Type: NGK Laser Iridium ILFER7C8EG 91898
AP1GczO-QpJjEn7Zj7RVIGsL6sW86qbPeaLFc9EGsudEKlKs2rv0eTGfhyUaHwBmrAWVWRfK_7qFnWnIb4lWVo-BjbcCEzA8Yx2j53mCplNevqIyFzp-Nr8TRGaS7xbttKvm1AGwVzmPjq8tY9lA6TZHj6I5HA=w720-h1280-s-no
AP1GczMHL04oxPxWFbzVTNoeo_lIoVunzpCBppyCpm8mVyZRJ5yQ2Tej0sf3omllaXPGSRUHAX3O_JzgB8i4hvV5-JxSNOtOtAo2ntnu8WxM46ZQRxfJtzCBj2gYlrCqpP8DBnqyKYKopc-DxH1-rZWMp_vJ_Q=w720-h1280-s-no
I posted this on Instagram hehe
AP1GczPIOo-QxkMG_MjLpyKj0gLFWhk-SqL6ibpVrVlx768pIqLgL2K4U9uAoO23oxEZWVXx7Irff4DC6aPlcUDswqiOfl6jvaE1SGlDX17Pbs2q6aQ8E3RXZnsiNmMaHCfo9F1cNVib2KXyW3qjDWBrlrGbRQ=w944-h1678-s-no
Its crazy once you get the results visualized :cheeky:
AP1GczN8UmDu1IXY5n7C7UjNGvGEdI-m_MzmcvtDTJ-7OiWcoP5bQPiygNYeacufdQloSvS2I8K69DxDR1fptuP69ARkQCDqgto0s5R-MC8_LEKg3iu5ZpY8vyGXdo8NXnGyMccb8gWcqZb5U-MCGKqzlX_p_Q=w1920-h1080-s-no
AP1GczPNQAOoYlktvLQjyOs2A7VYI2ErdyCVDpZcopF69bRr46OPBJdLTG8XQNuIORnOTsgODwebGtC7g33fy1oaPY7h7u-r0shvCMJStJruU7Wp4oOocQjkMz_W7BJoIC1XzUJa4rNi6dmPXqiB2j6tLhzXUQ=w1920-h1080-s-no
AP1GczP1RxiOAsow9_m8VxY7ezb7urr-dhfTOh6pHBdTnumDLXxSOZAbW9lBKDS7exrn3UE5AD7aW41ugD_Pu7jTHxjvGS3df3tNcmthpXemcisJAcfYshz7OAYsMxobPpW8CZLo3Qc7v8zUB8YnH2hEXNMBAg=w1920-h1080-s-no
Well done welcome to the Stage 1 Club you wont regret it.
And then a little bit later, I received the NGK ILFER7C8EG 91898 Laser Iridium spark plugs that the tuner recommended (y)
AP1GczOP6jXgiphOj-XY47JZ3gVSRw192rbuBNGxfQwJUVpY5vSVR87z3bFqMcTQqcwqhfmIFrOR4ngqlGY7WopAzx0uIRk2cGAsHh506rwVlw28_6rmtyS2ffHH1t1ocmqhfy37UigWUo2MssANvOXL31OXyg=w1920-h1080-s-no
AP1GczNqGaL114cHL1nhZAKkldLwKf4uNLNKQqCfDyyWwYrN9iwXwGpekTFpoJot-OYt6_UTJBkK9_OvP2-ZoPvF7n0X2qM7h5xU9GWj8j9a0KRPULsNEp7obhX7_t0HEpuNHGbtRAxIFdHWM-wdY5RmrdpWpA=w1920-h1080-s-no
The difference in the center electrode is clearly visible. The NGK has a sharper electrode
AP1GczNbdFBBnBUeW48c6Wg-vgxy7IqUECCDW7ZxVtbdWIdhXGL-yS8bVx5XkwhUcSG0kB9zc8ZVoLL2OtoCInkzdKLZmazMw7icdcEFj_Q6ooOMOidOiG3orIsmBD4AuHGWoq-T5QNwieGEa6k7lSwzccKwVA=w1920-h1080-s-no
AP1GczMmC0Vu5Ll-rsLHEvUdB9VSiqyGbrVIU7QJgsGNO5v6Ak0FBWAIBO2GeocrgIgT_iRTA2B-6AtHxDX89SUkepPYz9BavJsabAG-BZFbMQyL9yWZKibzN8P5QsLcp_ZPmBcCVlJNPy0ZLA5MblZlUg_FMg=w1920-h1080-s-no
This is how the Bosch spark plugs looked
AP1GczPo5RkdAhVGsiybbh2-N2OUgV8RX3FBOWNVELT_N4aXMQ45vpoxODqzxLJJ1L67Kb8LQPEklIGPvKWSp_BZL1XW9atcufhuSWW7OE47FTIu_1PU9RXiAP6dp4oR7GH61ZFtAE0doV1xBhZRXE00IKvj3Q=w1920-h1080-s-no
Replaced the "over the airbox" coolant line with a silicone "under the airbox" replacement. It also has a check valve like the original
AP1GczO0oNrYPJLZcp0sHg-oe3ocXdPp5YGpujsEkdihq7M8_DSkSdjvXpxhTffCzdXCwMCeug3oVqrNMawl_ABzTTnEXTc4MW8AuzTL2Tu93pBBrfpJ86M0zeUnRGuEcL6AgqPMzraUpa8vXIsC6U-hSE4HVw=w1920-h1080-s-no
The check valve
AP1GczPSEmKYpk0VFHtyjJLiVj42H1kJ-PafF0qyhjsh0HcatYMXRLlK-wtDN6q2HPqwt9pD_YmZ5_ubC6dr9TYLCkyqT9tfuQjp8zf5bnIXNaz_ZCFIV-lJqirYlRdf2zGBrgAcvCtRtFmBCHBfnUv_ns0Seg=w1920-h1080-s-no
Remove the intake snorkel for easier access
AP1GczM0ScKziNyWERAXfhtn3u2IU5mluBxBhhHMxD82d7VQ_k5NsdYttJ_ajGk4L18ufFK3_9TIa8dX8fdy7WG_cDwvoR1wDhGPcwAky-5_PvI3dGVW0XfueT4df9MI-7LD_b24Hb6idyA9A2fJx3Ddb27Iyg=w1920-h1080-s-no
AP1GczP0dGfR8VgC00miPq13q9AkVagKQIKLhetPZE7PPzgw_R0x3DpxxcpkPu-FpfmUbuUgW33hTYNYw-VEBy0UipxWMjHQFh0e5rYDfwvOB0q-tKWYDs3qsWfKsuFh_l2yAmGPQnRi1pZFPGsPCv_S97BYDg=w1920-h1080-s-no
Fitment was alright, but could have been better. This is a no-name version, the brand-stuff will probably have better fitment
AP1GczMeI2jCrnZRx5wSNZEf0UBVMjxoEaNrWUr6iTDsqm1HEaWZvRp0cQEKdxzwWN6kHkxI2a7khdFS4mdyjqTiVOW9Ky1pYGZWWzRfPpEUIH1hjwQNuKjmQAN-0wMzFpu8ApqJdeBoxJu6xyfl14sU5RmNVA=w1920-h1080-s-no
Still happy with the upgrade :happy:
AP1GczN9gtS6nFI-2T4iS2Sf3c3TbI1p3KBQAYQub4ZyB4qjPsRxGSFi94WNnVjEXMDtXnUZ-7ZCTouXziUKev9fCTStpOBJWKQS42Bz75HzGaUClzjxzwJ3oGZl2Nkrlywu9kReSJntQrExAZrxSEnChtDDyQ=w1920-h1080-s-no
Reactions: v11boy
Those Bosch plugs look like they have been super hot… how many miles had they done?
Reactions: nd-photo.nl
About 6000km. If I look at the NGK guide, they look ok to me :shrug: ? It does not look like the spark plug which is overheating. Let me know what you think of this (y)
The tips look good according to the ngk guide (number 2 going left to right 1-4) has some white deposits but all good - the threads looked like they had been hot, although I’m comparing to old air cooled Honda bikes!!
Not changed plugs myself in an E888 yet, but I expect yours are normal 😎
@v11boy Fortunately, its an easy job :) I highly recommend the earth wire modification for the coil packs if you are going to change out the spark plugs. It makes for a cleaner look and a more robust setup
Click:
Reactions: v11boy
Back in the day (before OTA updates) I would have said why wait just get on with your updates (I did from day 1) but I have to agree with the issues that modern car software are having it's not worth taking the risk.
After replacing the dogbone, why not change out the remaining 2 engine mounts :shrug:? And I am glad I did! Both units are hydro mounts, meaning they are filled with fluid to dampen any movement. The right side was beginning to leak, and the left side was totally empty. This explained the grime I found...
Right side engine mount, old vs new
AP1GczM3DbJl7l1eihLkWjx9XucCi-7cG953kKwCi87idSV0UYIwm_ttYaY9LsLVDM5iS5H656pJzh7wJVyqaYO9SKCLl8rrpt5Vqbtm-P0eF5a6jnmC2rTy7-BKNYomKVau1FHPudMuEKVVkea5Wz29mhpFAQ=w1920-h1080-s-no
AP1GczMEDs_cXN2noszxHz76htB4QO-Aj2naGSrEGAYIUnpIIP_gTgXgcM4uNWzRWF4mM4WFU9_vz5hmR8CtskdPgnDxBxcRClltKazJIoFjwbX-7QQV9mc8V3LdgYtmqV3DTAP8NB7GCCIdV6CDEaHrGGFruw=w1920-h1080-s-no
AP1GczMplYXTinSQSTrM4rv5jaxfbsr3NIkFZyvlkf-hlVZaE3f1ZkhJUJXDJQuVDiLOG0spgZJiYYONdrFap6JntWxUnpwVbFiSSvfaRKPWpWzYSwW9Zv4dTcCk2sdhcI6td9l7tt3HoFO2JtDXZ69X2xstpw=w1920-h1080-s-no
Some documentation of the installation date
AP1GczNguUT42bfWLTJUIvN_aVv_lsPbpIDqc0QMopRgyopG-PYno6Y6DhOTogmfSTVj0gVmK8Yo-OO14ztsLBEboPdoyhQwshvCIhW9Cn_R1sOUiXWixYl-jym4jyqH3dsXK_6gaBYSgdDayK1Xb3xFTCge9Q=w1920-h1080-s-no
AP1GczMTJW4zG2ALCjC3SzbCAGcS6Mfoq9yIXkljx1ztyz9K5uSf4_dfgYKbFo0rzI02pbEekvL0upYsBRQU0kZa1BCPwD7RsEajLRMtw_TPCXFs-jC8hU8IcomNGhWsXZrymsZXUiBmspmCAMUX5p_WBVw5ag=w1920-h1080-s-no
Evidence of some leakage
AP1GczOrge_1u6JjF6wtmzCGO1IwN5OX_mDoovaxdGkfwyDSfDHBvFrrDVliuaRVGcRFe6jEbyLYojtC8PXEz9JRFgT1QGs3AVZLIqTeXVkbbjV50aKpnfXGwVh6wWC80ne6HAU6kgkO6j49df3Pakucs2ZMQQ=w1920-h1080-s-no
AP1GczNN7Qdjqo06vQtpcnPyBlSJhZUB-V_sKGVk4jhecErQNFYiz9cKwKW2pNxLA6tb11nN5QpjEmJyiJ60cPf0KqWh1CdOpa5HjIOmIucswR0FuEt8FlmUldyLGpaUGZhi4zxkl2s1X-pIRSx5sT0PNlXi_Q=w1920-h1080-s-no
Onto the left side. This was more work than I anticipated. You need to remove some things to gain access, and then the access to the rear bolts is still pretty limited. The wire harness runs directly over the mount.
Almost everything removed to gain access
AP1GczNmKFzFbUGt_wUcGrWwb1d-PNclkefrMiJ65T4XbDAPyEBp6G_7ggz-n_AFd841o_s6vwYKMoLcWcWbChGCq2mJsTI1SuSTSFkP05sGvOoPq5s5US6Mtz7HeMFxs2LodMCVm6jM7m8USQxb4SN6S1YlHA=w1920-h1080-s-no
ECU removed
AP1GczPlg8KpkeInWXtu64ykKCVTBvXWoyPt7PtZ-RpNNmbjBon_hXAx9U2Ee7WYcWeY2V6PTd9_7LvDGkGSbxpbTgBvOjVAMt3HlpHpa0iSqDzHalIwwN0F5DS62yJvmuYgjQWs8FI9TjLgdPysW6lzgulnGQ=w1920-h1080-s-no
A better look
AP1GczNoPxHoFzAtAFQm-LoQ19UgnOtHiMuRWbdVwmn-CPLsEjfjNslxaAdkkl6pSK9ZjFoIVgHT18byGN_rtxPqOfJHT7aanRxQuhZvvUksCnOi1_PlQiM0eZoEiaW9VENEbvyMCRSeO9mJx9C-nNwB9JbbVQ=w1920-h1080-s-no
I think more of you work this way, with some template so you know which bolt goes where
AP1GczOfkVb0SRSqWQ1TuEtXdDWizWca_GQfMlhvYWPgAdJH44RlHZPzhzX5mrUhj-uVEVfIRgoA1KeiOFqlCH3QgS54XpQhChb7Zfa3LzjCodhJsKZ0RBVObOHo5UXfZ1p2oLuyM2cHwGSnQ4mpJ-p26tYt-A=w1920-h1080-s-no
Old vs new
AP1GczMj6TqXbZEy27wyVigE5juyIeCmfCUlANdB3yB98MXK5ippwa7eTYQrrnlYExSCB9kIqhsZxiRqqJrf6xKkJt9qM92yOXakuMc53n00w1NWBIhEoGDwhO6G_3xVKZhE9nI7D4_PZk8-8ze-xg37bp82yw=w1920-h1080-s-no
You can not see this unless you actually remove the mount. I was able to see some crud in the wheel well, behind the strut (no picture). If you see the same color crud in the wheel well, your engine mount is shot
AP1GczM4x0SWIKNrGZwdyHLCuhiQaboiVTA1IRZg9sAX2Y0EEXpbo4WqRwSJyEBRROBBkRMM7lAoGWnblR_bTvifVSzaLvN2I5N_8xtP7BLZgdEjGGMkduXOv9q4EvL8cv7Z4zSvNRXFDTyrKbgcGSIQ2ElhQg=w1920-h1080-s-no
Yuck!
AP1GczMoBOuls8SXxqjjmgxqQwpJOTV2NsQQdEIzv1PO9Rl_V-1e48sNbibJgbKdnyyshpRvkz6tdScx0ToIjQWJ-i2Roc9nCdqGGJE84v6_8HB2tI1oYmDf0eyYehnORlcMy7iBrgp83MWvPI6-mA_6c4cPzQ=w1920-h1080-s-no
Looking a lot better again (y) I didnt take pictures after the installation :)
AP1GczPLXWwVT4hUOAJY0qVQPwAOkS6ESvGWt1_P0RrBNK701CS_5d5b1t5bW_MExUqkxEYjktjpT4z8S7OOBHFo6k5Ih4l64S1K3vkuBNjNz-SWN331p_kNuJAotAAuP_wOFgvH6q6D8-etJvqrn-KWYrSWrw=w1920-h1080-s-no
Reactions: v11boy
