Think i'd be tempted to take off some hoses to see if there is much oil residue?
Maybe you can take off this elbow - and pop an USB endoscope in to see what the intake/valves look like?
example:
It’s funny you say this…
So the Mechanic that had a look said he believes there’s a turbo leak? Intakes and boost pipes full of oil. And plugs have oil on them….
Also running rough on idle which I noticed myself when sat in driving seat.
The frustrating and ironic thing is when I had someone have a look at start of 2024 - So 2 years ago. I was told pretty much the same thing…
So I had mentioned it when I went to get it serviced that year and I was told no it’s fine.
2 mechanics have come to that conclusion about oil the intercooler ans intake, yet when I was raised similar concerns 2 years ago - was told no issue.
Considering the charge air cooler was replaced recently I don’t know how the technician didn’t spot this?
It’s due to go back in April but I want to see if I can get it sooner
So now I have the battle of going back and actually getting them to have a look properly and not just the bog standard scan for codes diagnostics - which I can do at home.
Frustrated because keep getting fobbed off and I anticipate it’s going to be the same situation.
Reactions: Mr Pig
Did you get any pictures and is the engine actually using any oil over time, to the point you need to top it up?
There will usually be some presence of oil in the intake due to how the crank breather system works
Unfortunately he didn’t get any even though I requested, but I’ve ordered an endoscope. See if i can get some myself.
Will check oil level tomorrow
But when I first I dropped it off he said he already thinks there’s an oil issue…Based on the oil around the intercooler pipe.
And when he took it off said there shouldn’t be this much oil in the pipe and into the intake.
Did send a picture of one of the plugs:
These are the photos I got sent back in 2024 when another mechanic concluded something similar. They pointed issues with Pistons and Turbo?
Which I did forward on to Seat Lookers.
From experience, that's nothing out of the ordinary.
Good luck trying to get anywhere with Lookers...
Even oil on the plugs?
And oh I have no faith in them, it’s just due to my warranty.
Unless warranty work can be carried out elsewhere
All I want is to get to bottom of whatever is causing issues with rough idling and acceleration, and fuel lol
But guess might have to just cut my losses
It's doubtful that oil on the plugs will cause any problems.
A vehicle with a Seat warranty can be assessed and repaired by any Seat dealer.
Lookers is closest one frustratingly at 10miles
Non lookers is further 20 miles.
Which is also why the whole thing is frustrating not like it’s just up the road. So taking time to get it there and collect is always inconvenient.
Something must be causing issues.
I found it strange that your coolant temp keeps dropping down below 90 - maybe down to 86-87.
But then checking SSP555 about the 1.5evo and using google translate; it says this:
So this is probably working as designed - though we don't know what they class as 'high speed'? - would have been interesting to add your speed/load on to this graph - to see if these coolant temp dips correlate to your increased speed/load?
Your coolant gets upto temp in around 6 minutes and oil in about 17 minutes - seems 'reasonable' to me but be nice if someone else with a 1.5 could comment if this seems reasonable?
I don't understand why your actual and specified temp at radiator are so different?
The fan can also come on with AC demand - so not sure this is anything to be concerned about - unless it was coming on at 70mph?
I was thinking more about this - and I do think something seems strange here.
Your coolant temperature graph keeps dipping down to below 90 (as I pointed out) and this should only be due to if the ECM sees high speed/load.
So judging by your coolant temp graph your ECM keeps seeing high speed or load - and so reduces coolant temp. You can bet if it sees high speed/load it will also increase your AFR (run richer/use more fuel)
Why is it seeing high speed/load?
Was it a very hilly road?
What speeds where you doing? were you changing your speeds?
Can you do the same log again - adding in vehicles speed and throttle position. Would be nice to determine what speed it classes as 'high speed'?
Sure I can try grab some data this week, not sure what where I was on that trip you quoted.
So would like to see
- Coolant temp
- vehicle speed
- Throttle position
Anything else you think would be helpful to chart? E.g. do you want coolant fan?
Really appreciate all your guys help to try and figure what it is.
Endoscope came today see if I can get a chance to ply around with it and look in the intake.
On the 1.5 DADA/DPCA
"surprisingly" It's actually quite simple and separate - number 32 (on the TDI it's built into the whole cover!)
05E103495B superseded to 05E103495AP
Genuine is about About £100.
Thanks will keep that in mind and make a note, not too expensive to rule out I guess.
On another note, I’ve managed to get my car booked in at another Seat about 35 Miles away from me, for next week.
Was one closer about 20 miles away but earliest would be June.
Out the way but thought next weeks quite good instead of waiting months getting more frustrated as time goes on.
Hopefully they’ll be a lot more helpful than the place I’ve been back and forth with since 2023.
Going to collate any info I’ve got and send it on to them by end of week.
Just to follow up this was replaced when I last went, pretty much first thing they spotted that theres an obvious issue with the oil separator/PCV.
Doing an oil consumption test.
Still crap on fuel ofc but lets see what this brings.
Although I feel like I've come to conclusion its the 1.5 DADA engines that are just overall crap for fuel economy along with their other issues.
Seems like the DPCA & above are generally good on fuel, but if you've got the DADA you're stuck with poor fuel and unlikely to change.
Did a 40 Mile motorway trip yesterday returned around 31MPG :):)
Honestly wish I knew all this when I got it and just rejected it.
Annoying as I was originally looking at a 2017 Xcellence with a 1.4 TSI engine before I saw mine, which would have probably been the better purchase option.
VAG really just did a number on a lot of people with the first version of the 1.5
- Coolant temp
- vehicle speed
- Throttle position
Did you do any more logging? or look inside the intake?
Hey I didnt manage to do either sorry life just got a bit hectic.
I misplaced my OBDEleven but actually found it today
See if I can get some stuff tomorrow.
I do have some kind of update.
So I got my PCV valve replaced and had done a oil consumption test with dealer.
Car was still drinking oil.
Seems theres a damage to pistons...Which is causing higher oil consumption and allowing oil seep in.
Piston was mentioned to me at start of 2024 when I had an indepedant chck it out but Lookers dealer told me everythings fine - Which when I think back is frustrating as I could've got to bottom of this ages ago...
But this dealers findings are that theres scraping in the cylinder...Doing some research seems this is a common issue on 1.5 TSI DADA.
Theres a garage on FB based in Poland that apparently deals with this issue commonly.
A claim was put in for an engine replacement under extended Warranty.
They're now requiring more evidence and info - want a boroscope image of damage and then it has to be resubmitted.
I have to pay half the labour cost for this then Seat will pay the other half.
However the concerning thing that the gentleman mentioned to me is.
If Seat come back and require more evidence and the engine removed and stripped to asses further damage- I will have to pay half which is in the region of £400-500.
The kicker is if Seat decide to decline the warranty claim after this, I will then have to pay the whole labour cost to get the engine put back together and refitted into my car.
So basically if I go through all this I could be £1000+ down with no result.
