SouthernSeat
18
9
Hi all,
My 2.0tsi 190 (dsg) has a misfire/hesitation that comes and goes between about 2k-5k revs, most noticeable on the motorway when overtaking (although so far I've replicated the issue in 3rd, 3th and 5th).
It happens between half and full throttle in both D and manual mode and I've checked the RPM's and can see it isn't the clutch slipping.
There is no EML or fault codes present (or any that carista is showing).
A couple of weeks ago it had a service (including spark plugs) and the Thermostat housing replaced under warranty.
I didn't notice this problem before it had this work done...
Before I take the car back, has anyone else experienced this? I have a feeling they won't be able to replicate it and I don't want to be slapped with a £150 diagnostics fee!
Managed to get it to misfire enough to get some fault codes:
P030000 - Random Misfire Detected: No Sub Type Information
P030200- Cylinder 2 Misfire Detected: No Sub Type Information
Anyone had these before?
The P030000 has many possible causes.
P0302 looks like it could be either Camshaft position sensor - inlet, Crank shaft position sensor or Ignition coil 2.
If this fault only developed after new spark plugs - can you check that they plugged the coil pack back in correctly/firmly?
With a suspected coil pack fault, you could switch around your coil pack to a different cylinder - to see if the fault moves to a different cylinder?
I've had a look and found some dielectric grease (looked new combined with old crusty stuff) on the coil pack spring and end of the No. 2 spark plug. I cleaned it off (did all 4 actually) as well as giving the contact plate of each coil pack a clean with some contact cleaner on the end of a cotton bud.
After a test drive it seems all ok again but I'll update this thread for future reference.
Not sure why people insist on putting dielectric grease on stuff like that :rolleyes: Glad you got it sorted
Reactions: SouthernSeat
Agreed:
