Jun 15, 2026
Hi,
I am looking for some help with my RHD 2020 Leon.
I was away working for a year, and I left my car in a garage, I made the mistake of locking it.
The battery is dead but I was able to get in through the drivers door with the emergency key. I then tried to pull the bonnet release leaver to open the bonnet to put the battery on charge, but the lever is on the passenger side of the car and the door needs to be open for the lever to rotate.
I cannot open the passenger door, because its locked so I cannot open the bonnet. I cannot roll the car out of the garage because the handbrake is on and I cannot put it in neutral without power.
So for now my car is dead and stuck in my garage.
I am sure someone here has had a similar problem, can you please tell me how I get enough power in so I can open the passenger door?
Can you put power in through the OBD2 port? I cannot think of any other way of getting power in
Hi,
I had similar issues. You can bend the lever sideways and pull it enough to open it without issues. Most likely, your car also suffers from battery drain that is caused by the power steering unit. It has been fixed with a software update on my Leon 2020
Thank you I will try that
