Cupra Jon
77
64
Bit of a weird one this - since Saturday I've been getting the yellow triangle appear on the dash along with front collision warning/SOS fault and lane assist lights appearing on the dash (the usual ones you get in winter when the windscreen camera or the radar in the bumper is obstructed with frost) only I'm not getting them ob start up, usually about 3-4 minutes into a trip and once I hit over 30mph...
Then the strange thing is they disappear a few minutes later... Windscreen and radar housing are both clean so this intermittent issue has me puzzled...
Take it to the dealer, let them check for faults
Yeah - done that now!
Had a total of 4 faults come up but managed to make a note of them before they disappeared...
SOS Emergency Assist
Travel assist is currently unavailable. Sensor impaired
Front assist is unavailable. Sensor impaired
ACC: Sensor impaired
Gonna also get them to do the update for the flickering ambient lighting issue that they should have done at the first service in March.
Reactions: trew
Did you face really hot wheather when this happened? We had similar orange triangle about DCC system.
We went to the dealer and DTC analysis just said 'overheating'... Since temps have cooled down a bit, it hasn't come up again...
Started about a week before the heatwave but interestingly there are about a dozen owners of Facelift Formentors reporting exactly the same issues over on the Formentor Owners Facebook page so I dunno. Interestingly I received an update from Cupra earlier this week and, once installed my errors all disappears so thats left me none the wiser.
That suggests the update fixed it?
I was out last week and my VZN did this with all sorts of pretty coloured lights so I stopped turned the ignition off for a few minutes turned it back on and it was clear and hasn`t done it again!
A case of modern technology electrical gremlins more trouble than its worth
Reactions: trew
Im booked in with my local dealer on 4th August to investigate the same list of issues ...I have been documenting times and distances travelled since 28th of June .... I have have the issues every day to varying degrees of time frame up to the 6TH July but have had no instances of this since 7th July , although this morning the Infotainment system failed to start when i went out . 3 ignition cycles of on/off with a 5 minute wait in between failed to clear it .
I had no option but to drive the car without the infotainment system active , and behold , it started 2 minutes into my journey ..
  • Sad
Reactions: Cupra Jon
Steering wheel issue, the sensors in the wheel throw up all kinds of errors. Sounds ridiculous but try running the heated steering wheel, if no faults appear while it's on you have the dreaded steering wheel sensor faults. After multiple trips to the dealer for all sorts of fixes that didn't work I had mine sorted by @East Yorkshire Retrofits - was just thinking the other day how it has transformed the car from a constant bonging fault machine to a pretty decent drive. Just need it remapping now for a few extra horses.
@Cupra306Form So was this a coding fix or something else? I'm interested because my Formentor is also showing the sensor faults that appear to be steering wheel related.
Reactions: trew
I was out in heavy rain yesterday when two dash warnings appeared one was the orange triangle the other was the front collision gadget not working doesn`t that work in the rain if not surely that is a time its needed - after I had turned the ignition off and back on I continued my journey and they had gone - so whats that all about?
I have had Land Rovers that were more reliable than Cupra!
In heavy rain/poor weather the system can disable itself. It’s not ideal but it’s better to disable and inform you than stay enabled and not work
@Cupra Jon Did you get anywhere with your dealer regarding the 4 x Sensor Impairment errors?
I've just returned from Sinclair Cupra after its first service and had a list of issues for them to investigate with the main one being sensor impairment.
I specifically showed them this....
Regarding Sensor Impairment. Warnings shown are; "ACC: sensor impaired", "Front Assist is unavailable. Sensor impaired.", "Travel Assist is currently unavailable. Sensor Impaired" and "Error: Emergency Assist".
This happens intermittently during most journeys in the car, sometimes within 5 minutes and sometimes after 20+ minutes. The warnings come and go regularly.
What I got told was that they have seen the faults logged but cannot do anything as the faults were not present during the service.
I have photographic evidence of the faults too but when booking in was told, we don't need to see them, that won't be necessary.
@James_R Can I ask your advice on the Sensor impairment issue please?
My errors are as shown below. They are intermittent, sometimes show up within a few minutes of a journey and sometimes after 30 minutes. On longer journeys the errors can appear, disappear and reappear several times. The bumper and windscreen sensors are clean.
My dealers (Sinclair) have said they have seen the logged faults but cannot do anything else as the fault didn't appear when in for a service today. Stopping and re-starting the car clears the "reports" on the infotainment.
I think my next course of action is Cupra Assistance, as these are ultimately safety feature failures that should work. Surely if the faults are logged and recorded and I've got pictures of the faults, shouldn't any Cupra dealer be proactive in helping resolve the problem(s)?
Reactions: trew
I`m sorry but having looked for assistance with various issues from 3 Cupra dealers now and UK Cupra Customer assistance I am now considering to change my current Cupra but I will not be buying another Cupra - I originally considered that Cupra was designed as an upmarket vehicle when it is just an expensive Seat!
