If you want to apply a big optical transformation to your car, then I highly recommend adding sideskirts and a front splitter/lip. As usual, I wanted to choose something else than Maxton design and I found this German company called CSR automotive. Their products looked good and I gave it a try 👍
I was most excited about the sideskirts, I love the design of this "wing-type" sideskirt, just wow :love:
AP1GczOHuYfwplRZN6zuVQ4GrDA_8Vcj479E7YFGpMje-yO5cVO_4HDS4Fpc7W3_LBMJ3WjA_16I6X6LXrL2QHQyXfLGdbsfcLDeqs04vucn0efpE3HRx038Y17muhpiI3rSzNgP0uEYHy1HdBwvjxvIZX3egA=w1920-h1080-s-no
AP1GczOUM52bkFW8yWg7nUi_wGBYRE5Z8B3aXT0il3NFLB6YOZKft6_-VzZuwp9d0Zev4RAGUOzhURo5ygo1-SkG7-F2MSTiso9A2iXF8SsYtGlq1JddhRfKw66L8Dlc20KywUgfQFXLOhHwuX2ENOW98x5Tag=w1920-h1080-s-no
And then the splitter, a simple design which coincides with lines in the bumper 👍
AP1GczNs9FnyaKu2WEVT05fi_UJVhvPSYy3VoxTZdcHN7ZFdBDahTJ7L51-JL3QFN2Tj7e482PGBsXoDv-gg8o2RRvlvZnk4hWTbZyAcKikq5v8QKkX5wjqTa_lXzwYHJKYAExIySiF_Mo4Upx9DlzaZ427LOw=w1920-h1080-s-no
My girlfriend helping with the test fitment
AP1GczOnZia8NaHmy3ENoGbmW7TM8gcO5s0-VV_Vmcq5Cdy6ARImceZXcCJcF7UV7oh8azUSjECPJgtJ6SskWVOQbv2mRm05YYi-a-GGDS_iPbIP98k1l6psSgNwBYSr-s5JqpdDgHcyFUECIhUQsMOmz7UmNg=w1920-h1080-s-no
Yes, this will look good (it already looked good!) :cool:
AP1GczMAJf8XsXcQzc5POXR0OPKt7pfohAImTuAT6OuW0LRVursd0IzPb_JNIGo7Rc2KAlo3HT_qZii63KV_luP9fzMb21icl8Zf7quAZUSS7HYQUAN7mZ2DwVELri3wflAOgi6gGd9cxMCBoZs9PRZMH5Ws8Q=w1920-h1080-s-no
Stay tuned...
Time for installation! The sideskirts come with preinstalled high quality double sided tape, but I added some hightack kit or something for extra sticky power. I don't want these things to come off on the highway and even though the tape should be enough, I added some extra adhesive...
CSR gives you this surface cleaner from 3M, which works well
AP1GczMfmRJuRQecgkNKhmYO7o71M3ugYfzK0TPaf77Ux94ucbkLUBOTltu8vPEh-WPzMg6C08PlVesHB5twFcholyPqdjwqyXEyP8gs2Q1Le8_oYy_RHnQ64UUjRoQNDYw_rqSNnmDLH1MqKQPtRwdp1tE8bg=w1920-h1080-s-no
Extra adhesive added
AP1GczMvQgQh6ih9I2QAOda1YWZUzy5goTCrWL3Et18YAqSXSTOQgEeZy7Bj6At9dfwCEASFEDHaqWmIQzXDIOcepIBZ3F_Pa2W7Cwh9F-wFRHgfRz587K1Y8MGTC3caNCiMg0j2sk23QUqAQyuuUbqeXnyNkA=w1920-h1080-s-no
AP1GczMu4fr_la3gA05LVDW2UJ3n8PEa0EaEMLIYHEvLX0qVlc0HVdkPiBcTb5_Y_hQ0wqQkK4oBJJgsZ0aHNCGLmNdqdXlU011aXI9Jwn2uMEbKkquB-WlXTVREzyyby0YVLk4mOEC7hVR-WjU0tN0Wicyixg=w1920-h1080-s-no
Installation done, now we wait :sleep:
AP1GczOXGfvr5RWOpr0Pvo3JRtCjbfODOHl6MrJrENjyElXNCvU78xPcal78PI7JElTM3gIxLDKp7S_9q_pUKOZMyRMQ_PYSkEK52hLtdufBNgvHEfH8mZ2Pe8CwiNgbVRKM0KlzaARsPiaPzWRFpGNSPbwLYw=w1920-h1080-s-no
AP1GczOKDtcTw-4PZIQ2SaWs2unBtYt09ksoRA4P4fF2HScbQsCCH2MwMvJ2XvQggOzoGMnS3TQxKToiGfGOJ8ckTo8fsZuIXZvdjjMJk2gWTnExCDMJQ-OHisuEoS7UcF15z0I1hI10UD72ZYvbg3nVv95m7g=w1920-h1080-s-no
Again, I love the "blade" type design, looks very racey :drive1:
Reactions: Mo_86
And I decided to mount the front spoiler using rivnuts. Since I did not have that tool in my collection yet, I found one on Amazon. And let me tell you, this is a great addition to any "toolbox"! I used it on my girlfriends Opel Adam first, where 2 captive nuts on the frame came loose.
AP1GczNpJbcrvjcc3jok7pEUOSLPCQXHIZBB2pQk0g2jxOlrQuIW6JOK8PwbW4llI6nlF_q_dXnZcd8WsQfWR6TjQ97MFCmlNPdhpWa4SeTu4Al9EInVf3gWVTnNpzu-yks_GbEYcv1dMz0BS_7Q6wKMCWDR1w=w1920-h1080-s-no
Drilled out the holes
AP1GczPOeowRsm6SE2UEdeBGcBVJCv3Bgah9k0VwGNtax3ASxiR0SDZOkQccZjXWi44hknQ4Kt5ZbKX6UurfdUQ71ELnzOuWTxyQB3t0HntK-ITATx66MiBbu0a0t2K5mMH9U8i7aIHcMnV01moTu8HD5VCXRw=w1920-h1080-s-no
Rivnuts in place
AP1GczPgZDGfSA9qJwR-bAQfi4sBoTL8-LOqJBj98Eett0bwqFrxdYwSXsLLxnvj_KdceMbCSPa5jEKy7JNB-UWbG6ImiNPPdxMaNhT6sXcXzN-dgtTiryR_GDETB1YVOJMDFE9MOgj_yW0n4v2FipPBJpq_zQ=w1920-h1080-s-no
Secured!
AP1GczP1oQa70BkVzHiNHFpqG7ginSD0k_WlimwcgQ3wsqOXS7M0A8yEes0XNEQozPZYdqj9KaELJtwMv1HvQvJ7qaZQML-dr9x-KE9Y6OGZkkVrsXf6fLqYDhZsayM1tKplSehrvl2rSKc-WDMYJthmGdkLMQ=w1920-h1080-s-no
In the Netherlands we have a lot of these "humps" in public parking spaces, so having some clearance is nice. This is the clearance with stock ride height
AP1GczMu-IyrgzW01yyo6pIZnT9WOsYbYH9NJ9Q1xnk5NzDJwKtwhdsv2FIFjDTNkjEcuLTv3LtmXfe1ceAEb8ywTYbgk3HiZ1ZqUwtrEDcpKrGm39rj41fitXk_c0PtksJZ2LrBFkWd0PYKC-uoQuHmE7Ig5Q=w1920-h1080-s-no
AP1GczPtU1iiZan5XQzbIQuHXij_UGvEo3lIrnIctTGCqS-HePU1x4kYzX1SV50RcmORTRsNZEkIVj5JO1DCMkE2L8n4MMkTnn9GO8zTaKthN4uChF8unGUkxSAQXzQr5H20e7UTztoUoHuVKLb9OtJiKY0aaw=w1920-h1080-s-no
I love how you documented everything that well, congrats, also did you lower the car? Because i would like to but you know how NL is with the bumps and everything
Thanks a lot, I document everything for myself, but also to help others who run into the same things 👍
My ST is not lowered, stock springs & stock Monroe DCC dampers. The rear has been refreshed in the meantime with new Monroe dampers & Eibach springs, but they are not the pro/proline lowering springs, but 1:1 OE replacements.
I surely love a lowered look, but I wanted to keep it practical for me 🧓
Reactions: Mo_86 and ashtrotek
Posted the video yesterday for installing the KOZO 3.5" heatshielded downpipe. Unfortunately, I did not film the whole process as it was quite difficult to remove the original downpipe as space is tight. Installing the new downpipe which consists of a few parts and does not have the big catalyst directly after the Vband, is way easier.
This downpipe bumped the performance of my ST 280 to almost 300 according to the tuner. More info: https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5096678
Some relevant partnrs:
V-band Clamp IS38 turbo: 5Q0253725G
Turbo Exhaust Gasket IS38: 5Q0253115B
Exhaust joiner downpipe OE Cupra catback: 65mm x 87mm
Bosch O2 Lambda sensor (post cat): 0.258.030.524 / 0 258 030 524 / 0258030524
Reactions: ArchNemeziz
@ArchNemeziz No drone, as I still have the original catback with the big resonator and the dual mufflers in the back. Even with the cutout valve open, no drone 😍
Only the first part is 3.5", it steps down to 3" pretty fast and in the end it steps down to 65mm for the original catback. I highly recommend this downpipe, very good quality for the money. I paid about 470 euro including shipping and import duties (in the Netherlands)
Replaced the pipe joiner between the KOZO downpipe and the stock catback. It felt a bit loose with the previous clamp (happens over time). This design with the 2 separate clamps is more traditional.
AP1GczMM9WH5RDWsfyLl34jQcho3rypiEB5bOlJ511nCsHJLW-EVlVlbajxTRyc67EpMcfWr2RPdhCYt-L8uwd6STYldvNw0nOyNVRX7LhQY-VR3wzVE771gywU8RI0gh7FnBLjruXtR18dhZmI1Z61a8zdypA=w1920-h1080-s-no
Checked the clearance between the downpipe and the bracket, seems more than ok 👍
AP1GczOhPltfruNN3JGS1sRCkLVCRuFoe7hcDVKesnxLWVjQ6Nuqo2N75Gn5XHEGDGPQ5Ie_vg9U_4oAwX-H2ngfNhYcomZrCSIZcg1Lm3FNTkC0LRUxNTXjZ61eJkFb0h07ARn2Ly8s4UjgYFqWDsdH8aH9BQ=w1920-h1080-s-no
AP1GczNvF1h-hIWoT3iRmt0L_oW0NW82-2kfalq1PiS0quFm_L8wY0RUMK6ZuBAa7L0RFltbXemDnCE-D7LLO4CfYCrHkZMc3NcNCkzG7O4IoobS6NXjOejGuQ29A5mddcHWIDkNqK7h2OkJWImshqxlcTEK8g=w1920-h1080-s-no
After replacing the exhaust clamp, the catback was sitting with less stress, but unfortunately I developed a "cling cling cling" sound under certain conditions. I traced the sound back to the 2 stumps from the downpipe which were banging on the subframe. I cut the stumps down ever so slightly and problem solved.
I have been driving around with it for a while now and the downpipe still sits securely in the hanger, so no issues 👍
AP1GczM_j6Sy2Z2ewyp9oCppdOJUTv8PiEbs_U9Y91H1kT2ubVGKTch8ZWVsO-NQiR1YIC292QAqF8HoEW2wsOAVoiztvJ757KYmxTpPdRAPDdwmK-oPntqUGfllghYJuizUpiOxr0MWix7wA87y1s9JWbD_sg=w1920-h1080-s-no
Chopped!
AP1GczN8yFmm_Vf_LoWmkBkxk_H4FW1u1lmx4iDsBeiJunRW42FrbN15tCWZTPHGjPxN2dtwnKsf4I0xjWb3Ik0qRMcDnIP4z0bQkzWGiIkU16GhPihp_YwS7YeUv2VUQNNuFYwVY60PKAMp6t7Q9wk9NAoUZg=w1920-h1080-s-no
Proof that this was the issue
AP1GczPEowP_3_LReUzDE3Cpi90nRQH_dX2NizKzEvRCqt0bya1sPD9DVlojiJhu4j1WvoV8QSdxpmZgCvxU6Y22tosIWfc05AukTMcNnkKjf0XFUu_Lw5QwH9ZRW8BKT5gNnDpKIO_3esMuBiWG9SiaQ8TX1g=w1920-h1080-s-no
Reactions: tracktoy and Mo_86
Chopped!
Isn't the DP supposed to have rubber mounts on there?
