You'll find the plugs actually split in 2, 1 smaller plug with the smaller wires and the 2 thicker wires in each plug stay in the main housing. If you want more ease then you could de-pin those but it's not critical.
It might even be not both plugs are in the left side and it's only 1 you need to get through, I don't have my car still so I can't check on mine sadly.
Many thanks for this, much appreciated.
I will give it a go next week.
Reactions: Craig.
Hi All
I finally swapped the grommet over today and it went ok, I did however have to depin all plugs to get them through the tube, there must be more wiring on my car. It went ok with plenty of pictures to remind me where each wire went.
Many thanks for the help.
Reactions: Walone
I’ve ordered a de-pinning kit - any idea how many connecters are there?
Also, did you use any lubricant when feeding the cables through the grommet? I was thinking of applying a little silicone lubricant to both ends of the grommet and lightly coating the cables as well to help them slide through. Do you think that would be okay?
