You'll find the plugs actually split in 2, 1 smaller plug with the smaller wires and the 2 thicker wires in each plug stay in the main housing. If you want more ease then you could de-pin those but it's not critical.
It might even be not both plugs are in the left side and it's only 1 you need to get through, I don't have my car still so I can't check on mine sadly.
Many thanks for this, much appreciated.
I will give it a go next week.
Reactions: Craig.
Hi All
I finally swapped the grommet over today and it went ok, I did however have to depin all plugs to get them through the tube, there must be more wiring on my car. It went ok with plenty of pictures to remind me where each wire went.
Many thanks for the help.
Reactions: Walone
Was it easy to slide the cables through the grommet?
Unfortunately not, I have to de-pin most connectors to pull the cables through, impossible otherwise, just mark things up and take pictures.
I’ve ordered a de-pinning kit - any idea how many connecters are there?
Also, did you use any lubricant when feeding the cables through the grommet? I was thinking of applying a little silicone lubricant to both ends of the grommet and lightly coating the cables as well to help them slide through. Do you think that would be okay?
No lubricant required, without the connectors the cables pass through easy enough, also dependant on which side is being replaced the rear washer pipe may also pass through, there is a joint which can be pulled apart.
Thank you.
What joint is that?
Thank you.
What joint is that?
If you need to replace the side with the washer pipe when you pull the pipe gently a joint will appear, to seperate just release a little black clip and pull the pipe apart, to join just do the reverse.
