Thanks for the insight.Just dropping the coolant, and filling up again does not have the same possibility of trapping as much air as actually pulling of the thermostat housing/pump, and fitting an empty housing. These are very complicated cooling systems with multiple circuits, one way valves and pumps.
Of course a faulty new thermostat is 'possible' - but for me I would say you have more chance/risk of trapped air causing your problems than a faulty new stat.
Trapped air could cause your symptoms as well as a stat, as it can prevent the pump from properly pumping due to cavitation, restricting coolant flow!
A vacuum filling kit isn't expensive - if you don't have a compressor for the venturi, you could probably rig up some hand operated vacuum pump.
You can test your stat opening/closing with some hot water to determine if it is the new stat which is faulty.
Ok, I get it and it actually makes sense, as the housing is full of routings, two stats and the pump, which could cause some cavitation from the impeller.
Unfortunately I don't have a compressor neither a garage, so I would have to use a hand operated pump, if that's even possible?
Testing the stats means I would have to removed the housing again and open it, which could void the warranty in case I have to return the part.
