slamka33
330
14
Hello all,
have a new Formentor since beginning of March, but have already an issue with 12V battery. Car was parked for ca. 2 months at the dealer before delivery (due to contractual reasons), in the winter (end of Dec. until beg. of March). So the car immediately at the dealer during hand-over and some introduction to that with ignition on posted message that "12V battery is low, start the motor". I can imagine that this 2 months without a single movement did not helped..
After delivery I tried charging with cheap charger, but I have feeling that it did not helped too much, measuring the voltage on battery shows only about 12.0-12.1V after charging. I made a highway trip of 400km recently and the same message "12V battery low, start the motor" appears at the parking lot after driving 150km.
So thinking of buying better battery charger, but I have some questions which I cannot find answers to. Unfortunately, the battery itself is somehow hidden in plastic cover, so I am not able to read specification of it.
  • Is it EFB or AGM battery? I am considering buying CTEK MXS 5.0 charger, shall I switch on AGM mode or not at all?
  • Is it normal that after 150km the battery might still be low?
I did not have any issue yet with starting, only the message appears so I started it up immediately and let motor running.
During the city driving I switch off as well start-stop system manually, so at the red signals motor is on.
Thx.
I am crazy out of this 12V battery and the design how Spanish designers covers it with plastic cover for NO REASON!
First of all, I am not able to put down the plastic cover without opening "+" contact, there are two cables connected OVER the cover. Why the hell ?!???
Secondly, the purpose of the cover.. What is it for?? It just hides information written on the battery! There is no single another reason why it's there!
Tried to read as much as possible by lifting the cover without braking it (I really don't want to open + contact just to read what is on the battery!). I have been able to read only three things:
  • 70Ah
  • Pb
  • 505 915 089, 420A
Can anyone tell me if it's EFB battery or "common" one?
I am confused - everywhere I read that new cars with start/stop system has usually EFB of AGM battery and it looks to me that my new Formentor mild-hybrid with start/stop is old Pb battery style?? Really ???
Reactions: Steve-Formentor
  • 70Ah
  • Pb
  • 505 915 089, 420A
I have a 1.5 eTsi 2026 and it is fitted with a 70 amp hour AGM battery, it is very well specced, electric seat, heated seats/steering wheel etc. I believe the spec can make a difference to what type of battery is fitted. I have never had a "12v battery is low" message so suspect your battery health is not good, probably due to it being left unused for a couple of months. You may have to have the battery replaced to cure the problem.
This is what I am speaking about. The cover on the right side covers all spec of battery. The only things I see is 70Ah and Pb.
I saw lot of other pics of battery in Formentor, where "EFB+" sign is on the location where I have "Pb".
My spec is as well high, the highest possible, except sunroof which I don't like. Otherwise it's all in - sound system, electric seats, heated seats, steering wheel, 360 cam, kessy, HD lights, all assistants, even trailer ball (or how to name it in English)..
That's why I am surprised with "PB"!
No EFB/AGM sign anywhere....
Have you tried putting your registration number ( or the exact model of your car ) in to one of the battery suppliers websites ?
That should bring up the correct battery type for your car.
Pb is the chemical symbol for lead and it's marked on pretty much all 12v batteries.
If you can't see an EFB or AGM marking because of the plastic cover, have a look at the lower casing of the battery, if it's black it tends to indicate that it's an AGM, if it's white then it's EFB/EFB+.
  • 70Ah
  • Pb
  • 505 915 089, 420A
The code ending with 915089 points to a part number but it is needed in full to make sense.
The initial number 505 does not seem to belong a VAG car, can you check again to see if it could be 5QS, not 505 ?
And any letter at the end, like C, AC or BD ?
By the way, we can look it up using your VIN, to see what kind of battery was installed in the factory.
If you send me your VIN via a PM, I can do that and get back to you.
