That is what I wanted to indicate here if you know what I mean.
Oil is showing full when cold on dip stick.
When it would reach to its operating temperature then level would only increase like you said.
And its been more than 5 days in that situation and no oil traces so far.
  • Wow
Reactions: CupForm
I'm sure it's the other way round, as when cold all the oil has drained down into the bottom of the engine and if dipped cold will poss show above full. When you run to temp the oil is all around the motor so dipping it then will show less, but should be in the area marked on the stick.
Well that was my understanding old school thing.
But reading here on forum told me something else.
It would raise the oil level due to temperature.
Ok, i got an update.
Just serviced my cupra, second service, 7600miles. Seat Letchworth.
I've been treated very vell, asked for mechanic, expressed my complaints, worries, and got somewhere.
- oil in intake, mechanic told me as it is new car, it will be some, but till first service ( dont know why), but he presented that to cupra a while ago, as he noticed some cars coming with the same problem, and as he said, some air filters need to be replaced earlier than scheduled.
He also confirm that filling the oil to max may have caused the issue.
I have aske to fill half dip stick, and one litre of oil for top up. They agreed.
I was charged for that 1 litre of oil 17.99, and for washer top up without asking, but my whole bill was reduced by 30%. So no problem there.
- issue with noisy suspention from new, they told me top struds mounts bad quality, ing booked for replacement, under warranty.
- big software update, screen, headunit, ecu and gearbox, i think it sorted my issue with reboots of the infotainment
- GOT MY ENGINE COVER! yuppii :cool:, nothing special, simple plastic ,but looks good, no cupra loogo.
Will update regarding oil in intake in a while.
im not so sure about it, it does not matter cold or hot, oil will go down, faster when hot, slower when cold, but it will go down. When warmer it expands, and i have reconfirmed that many times, currently on cold engine i have half way dipstick, when engine hot (over 90 degree) dipstick indicator full.
and i think it sorted my problem with oil in intake.
I also got an audi A6 c7 1.8 petrol, no dipstick there anymore, but borrowed from my cupra, as engines are almost the same, and same thing, with one diference, 3/4 on dipstick when cold, 1/1 when hot, so not so much difference, and no oil in intake.
OT: One thing, i went to Skoda dealership today, been looking at the Skoda Kodiaq 2024, and the quality of the finish, baterials used, sound system, that is a beautiful car!
Waiting for the vRS version and will swap i think!
My new egine cover! :cool::cool::cool:
but somehow i fees really stupid for being happy to receive it after almost 2 years, when it should be installed from new.
For me so far so good.
Although oil level is at the top most. Happy days.
Probably engine new verdict seems right.
I am at 10k now.
Noticed the same issue on my car too, oil on air intake connection pipe (Formentor VZ 310 2022, 64k). Took it to the dealers, but all I got was "yes, this is a known problem, but unfortunately the manufacturer don't have the solution yet", so they just cleaned everything up and let me go. Has anyone encountered the same from the dealers service? And maybe someone who has the same issue got it fixed? And what could be the consequences of daily driving with this issue?
Was this the clunking noise over bumps?
Mine still does it sometimes and read some changed the shocks with the Ateca ones and problem solved. Taking what the y did to your car maybe it wasn't the shocks but the top mounts that most probably were changed along the Ateca shocks!
Could that be the case?
Going for the 60 k service next month and would like to let them know.
Hi guys,
New owner here. I recently bought a Formentor VZ 310, manufactured 01/2024.
Yesterday I noticed the same issue with my car. There’s oil in the duct on the air filter side. Oil deposits are visible on the T-joint right before the turbo inlet, and it’s not “fresh” — it looks like it’s been there for some time.
The car had 18 600km on the odo when I got it one month ago.
Previous owner had done the first oil change at 11 300km (05/2025) and now I’ve just done the second one at 19 000km.
The old oil had done ~8000km and was right in the middle of the dip stick before the oil change.
You are doubting the mechanics for overfilling and not knowing how to check oil level properly but according to the service manual the amount of oil for this engine is: Capacity 5,7-6,6 liter (Service fill)
So basically the dealer (including my mechanic) follows the manual and pours 5.7 liters, then checks dip stick and calls it a day.
To be fair my mechanic poured 5.5L and said "Check it tomorrow morning and if you decide you can top up".
So the next morning i checked and added another 100ml and now the level is at max when cold.
But today I checked according to the procedure in the hand book (warm engine 3 minutes after parked) and the level was actually 2mm above max.
Maybe VW/Seat/Cupra shoud be more precise when writing service manuals....
My observation, over the time it would be less and less likely visible, My car is now at 35k miles. It was more visible when was new. I have seen instances when car oil was filled above the max line and there was very little oil there. So my conclusion is probably parts are were still bedding up. But its bit less now.
