Lewwy
L6 WWY
Feb 5, 2012
52
Bedworth, Warks
Leon 1.4 TSI mk3 FR (2013), CHP engine code. The steel oil sump has corroded and now leaking oil (car has done 49k). Anyone else done a sump change that can offer me any advice, part numbers required, links to tutorials or videos? any input greatly appreciated.
It seems that you will not be the first to have this issue, that is one reason why I prefer to drop the oil out via the sump plug - and while performing an oil change that way, you should be checking over the underside of the car, and so catch this issue early and hopefully stop or slow it down before the sump rots through.
Many years ago, Ford changed the paint on their smaller engines from durable black paint to grey paint, my wife's 1992 Ford Fiesta's sump caught me out, and I replaced it before it became porous - but, I wiped the new Ford sump with meths to degrease it before re-painting it with black Hammerite, wiping it with meths removed all the thin layer of grey paint!
So, maybe you should degrease your new one and smother it with the contents of a small tin of Hammerite paint.
Actual details covering removal and fitting I can't give you, though make sure that you know if a gasket or liquid gasket is used to seal it, I'd think that it would be liquid gasket nowadays.
Edit:- it looks like your steel sump part is just the "lower sump" ie really just a closure to the bottom of your engine, if that is correct then it should be slightly cheaper, p/n for CPTA version of that engine which claims to be the same as CHPA, is 04E 103 602 B and the sealant is listed as being D 176 501 A1. Now, at the age of your car, maybe it makes more sense to source an aftermarket equivalent for both these parts, I've never needed to look for aftermarket steel sumps so I can't help there - but a good local motor factor should be able to find one for you, though maybe phone your local VW Group dealership parts department for a price and to confirm these part numbers.
Edited to change "was" to "with the contents of" .
Hopefully not, that looks nasty, hopefully, by the time the OP's engine was built, the sump was just more or less a steel plate that covers the bottom of the engine, that video shows an alloy sump pan.
Agree on those part numbers for the lower sump pan from a 1.4 CHPA
Additionally just in case - the bolts are:
N 107 480 01 Hexagon socket head collaredbolt, thread forming
6X16
qty
19
Looks straight forward to swap - though you'll need to also swap over your oil lever sensor - which you should probably use a new seal - 038103196B
I noticed a rust patch on my sump pan a few years ago. Cleaned up the area and painted it with Hamerite paint. Still rusted through!
As a temporary patch I managed to seal the leak with Arldite two-part epoxy. I managed to get that to dry quickly enough to stop the leak without draining the oil. It held until I had the time to get the pan replaced a few months later.
I didn't replace the pan myself, got a local garage to do it.
Reactions: Mo_86
Hey
Would you know what torque to do bolts (the sump ones and the oil level sensor)?
