Nov 3, 2023
I have a Seat Arona FR 2022, wifi & hotspot are not working after doing factory reset, before the factory reset all was working fine (wifi, hotspot & car play), the wifi hotpot switch becomes off immediately after enabling it, and wifi is not showing any nearby SSID
here is a video of what's happening exactly
also attached MIB3 version & FEC/SWAP codes activated
I have same problem on Seat Leon FR 2021
after factory reset I can no longer enable wifi or hotspot
tried updating to 1969 but still not working
Has anyone managed to sort this yet? I've resorted to resetting my phone, trying my partners phone and an iPhone. No luck.
Vehicle and sofware detail
I have a LEON SE DYNAMIC TSI EVO TSI EVO SE DYNAMIC 2021, running MO13_EU_SE_R9400L.
Connect app expired and I don't plan to renew.
I use Android auto connected wirelessley to the infotainment system.
Samsung S24 Ultra
One UI 6.1 (6.1.1)
Android 14
Android Auto 12.8.643614-release (128643614) - I was orginally in the beta programme but have since changed to the stable version.
Issue
Vehicle WIFI not working
Wireless android auto not working
Wifi hotspot not working
Wired android auto working (but intermittent connection)
What I have tried to resolve the issue.
1) Completely reset head unit and setup again as primary user
2) Rename head unit wifi and passcode
3) Reset all network settings on my mobile device
4) Since purchase, all head unit updates have been done over the air
5) Connected car to home wifi and waited for an update. (It does connect to my phones hotspot and my home router ok)
6) Attempted to connect my partners Samsung Fold 6. (Same issues)
7) Purchased a data plan for the head unit
8) After data plan purchased, attempted to connect to the head units WIFI hotspot
- The phone won't connect to the hotspot stating that it could not obtain an IP
9) Contacted dealer who doesnt know a solution without bringing it in. They did advise a later software verision was available 1969 but because it is out of warranty, would charge to update at the dealership.
10) Factory reset phone.
I am at a loss at what to do. I do a lot of driving for a living and rely on android auto.
I tried connecting an iphone and this seemed to work wirelessly with apple car play but again was intermittent.
Any guidance would be appreciated.
Apologies if a similar issue has been posted elsewhere
Another piece of unusual behaviour I've noticed is that I can't turn off Eco tips anymore. The toggle is switched to off, but the dash still displays, lift throttle to coast and often states it's a 30mph road when it's not. Software seems very glitchy recently.
Magic up @East Yorkshire Retrofits see whether they have an answer. For sure it would seem never do a factory reset on these units. A reboot. A long hold is OK on the on / off.
I dont think doing your own firmware updates on these units is very sensible since they are like a pack of cards in how the systems are connected that was found with the Formentor. Hmm faint bells ringing of people might have said disconnect the 12 volt battery in the past - that will bring all systems up as a reboot. If it's reliant on other systems being refreshed. Failing that poor design. A connect services contract and you have come back with the dealer. :unsure:
Reactions: abidat
I own a 2023 Arona FR equipped with the H59 module. I spent a lot of time trying to activate wireless CarPlay, while most retrofit shops wanted high fees to fix it.
My main issue: whenever I tried enabling WLAN or the Hotspot, it instantly toggled back off (even though I had enabled the corresponding menus via OBDeleven).
The fix turned out to be completely unexpected.
Due to regional 5 GHz Wi-Fi regulatory restrictions, the MIB3 unit must verify its location via GPS before allowing 5 GHz broadcasting. Since my factory unit lacked a GPS feed, I simply purchased an aftermarket GPS antenna/module, plugged it into the back of the MIB unit, performed a hard reset, and drove for about 5 minutes. The unit locked its location, and wireless CarPlay immediately started working smoothly!
Reactions: Tell
Hi Gokbulut !
Your solution is exactly what I was looking for. I am facing the exact same issue with my Seat Ibiza (imported from Europe, and the WLAN hotspot instantly toggles off after a factory reset that I did outside the Europe).
Could you please help me with a few specific details on how you did it?
  1. Which GPS module/antenna did you buy? (If you have a brand, model name, or a link, that would be amazing so I can buy the exact same one).
  2. Where exactly did you plug it in? Is it on the back of the screen itself, or into the main unit located in the glovebox? What color was the connector?
  3. Did you need any specific tools to remove the trim/dashboard to access the back of the unit?
Thank you so much for your help, your post gives me hope to finally fix this!
Reactions: Gokbulut
Hi Gokbulut !
I think 1. got answered here:
There is a fix thread that @Gokbulut did which I pinned subsequently. Let him answer the rest.
Reactions: Gokbulut
Hello,
For the Ibiza, reaching the unit to use a Fakra GPS antenna might be a bit more difficult. However, if it is in the glove box, there will be an empty blue socket there. The GPS antenna you bought will be compatible with that port, so you can easily connect it this way.
For removal you need this tool;
Reactions: abidat
I bought these ones to remove a mib2
Youtube videos show the action. Flat side out, click and pull.
Reactions: abidat and Gokbulut
Hello,
Hi, very helpful, thanks a lot!
There’s just one thing I’m still trying to understand: why didn’t this issue occur when I performed a hard reset while I was still in Europe?
If the MIB3 needs to determine its location via GPS to apply the correct 5 GHz regulatory settings, how was it able to determine the European region after that reset in europe? Does the car already have another GPS antenna, or maybe the unit could be using another source such as the eSIM/network ?
Could this explain why Wireless AA continued to work normally after the reset in France, but stopped working only after I performed another hard reset outside europ (North Africa)?
