Happy Ant
70
16
I had a Vantrue S1 Pro Max dual front/rear camera professionally installed, however I have had some recent issue that I have discovered the supplied VP03 hard wired kit was actually not the correct kit for a modern MHEV eTsi car with its modern onboard computer systems. I have tried several different solutions including plugging in a kit direct to the OBD socket, but that to caused a battery drain when the car was switched off. I have contacted Vantrue about this issue and have got nowhere, sadly the original installer is no longer available and local car electrician are not interested in touching the car even though there is no chance of them damaging the manufacturers systems or cabling, but they do not want to risk it, Does anybody know if this solution would work please?
By switching from the faulty hardwire kit to the armrest socket, the behaviour of your car completely changes:
  • True Zero-Power Sleep: In modern SEAT/VAG vehicles, the centre armrest 12V socket is strictly managed by the vehicle’s main computer. The second you lock your car and walk away, the computer cuts all power to that armrest socket after roughly 10 to 15 minutes.
  • The Camera Shuts Down Physically: Because the socket goes completely dead, the power source is cut off. Your camera is forced to shut down entirely, meaning it is physically impossible for it to draw a single milliamp from your car battery overnight. Your flat battery nightmare is instantly over.
  • You Keep Your Hit-and-Run Protection: Because you already have the camera set to Collision Detection, the camera will still protect your vehicle. When the armrest socket goes dead, the camera will shut down, but its internal G-sensor will remain on alert. If someone slams into your parked car at the shops, the physical impact will wake the camera up instantly using its internal supercapacitors, record the incident, and shut back down safely.
You haven't wasted your money on the S1 Pro Max—it is an incredible camera. The only broken part of the puzzle was the wrongly supplied installation of that old VP03 wire. By simply moving the plug to your armrest socket, you bypass the bad wiring, protect your expensive hybrid battery from damage, avoid the fierce Costa Blanca summer heat risks, and finally get the peace of mind you bought the camera for in the first place.
Does anybody have any opinions please?
Well it was a professional company that carried out the work in the first place
Mistakes can happen, I would reroute the hardwire kit and use the correct fuses.
I've been using my viofo a229 plus in parking mode and had no issues with battery draining. It just shut off when detected voltage is low.
What car do you drive? Is it a new mhev?
It is not, it's a Leon mk4 1.5 TSI. The internal fusebox should be the same btw.
But the BMS is different don't forget my car does not have an alternator. The 12v battery under the bonnet fires up the 48v main battery, if the 12v drops below 12v it fails to even unlock the doors. The dash cam is wired up correctly but the voltage cut off is limited to either 11.6v or 12v which drains the 12v battery too low and hence drains the battery too much. I should have been supplied with Vantrue's VP01 kit which has a 12.5v cut out.
So my cars electronic system is different to yours
That's why i'm saying that the hardwire is connected improperly. The voltage should not drop under 12v, if that happens that's because the "acc" cable of the hardwire is plugged to an always on fuse, so it always bypass the other cable and the cut off controller won't work at all. Yes, you are right the electronic system is different but in this case that applies to the the way the 12v battery is charged, not when the car is off.
If that is the case then i am stuck as the original installers is no longer available and I do not have the technical skills to correct that nor can I touch the fuses without invalidating my warranty and finally I can find no local installers who are willing to risk doing anything to a new car for fear if any does go wrong seat will refuse to honour the warranty. I have several different companies and all have virtually said the same thing, I guess I am stuck
The installer might have used some empty fuse slot, so I don't think you can really void the warranty, unless you mess it up badly. A picture might help to diagnose that, just to be sure it's not what i'm saying.
Looking at the VP03 user guide here, it has an inline switch that should power off your dashcam if the car's 12v battery drops below 12v or 11.6v, depending on how the switch was left by your installer. Perhaps it's been left at teh 11.6v setting which could be too low for your cars setup?
Can I suggest taking the car to an auto electrician or known good garage, they should be able to work backwards from the fuse tap (in your car's fuse box) via the VP03 wiring loom to the in-line switch (shown above).
Sorry but i am 75 years old there is no way I can bend down to open the fuse box let alone touch anything in there
lol
I have looked and the switch is set to 12V but in a new MHEV engine that is already too loo hence my issues with my 12V car battery, I should have bought the VP01 kit with the Voltage cut off at 12.4 but was never informed by Vantrue about the potential battery drain issue, hence my problem at the moment.
As for auto electricians I have tried three different one's and all have said they will not touch wiring or fuse boxes in a modern MHEV eTsi car as the BSM systems are too complicated and I should take it to a SEAT dealer, I tried that and they were not interested either, hence being stuck
@Happy Ant The VP01 hardwire kit can turn off the dashcam when the voltage drops below 12.5v as you indicated (see below).
I am surprised that auto electricians are reluctant to help you out...its their job after all. Keep on searching as there must be someone that can help, don't give up.
Not having a MHEV car myself I did a little google on the subject and it said....
"There are two safe ways to handle Parking Mode in an MHEV:
1. Use a Dedicated Dashcam Battery Pack:
This is the most recommended solution for hybrids. You install an external battery pack (such as a Cellink Neo or BlackVue Power Bank) under the seat or in the glovebox. The battery pack charges only when you are actively driving. When you park, the dashcam draws 100% of its power from the external battery pack, completely isolating your car’s electrical system.
2. Hardwire Kit with Strict Low-Voltage Cutoff:
If you choose to hardwire directly to the fuse box without a power bank, you must use a hardwire kit that features an adjustable voltage cutoff. Set the cutoff very high (12.2V or 12.3V). This ensures that the moment the dashcam sips too much juice, it shuts itself off immediately to protect the car's starter battery."
So it's not impossible. You've just got to find a competent auto electrician.
Just doing a search around Alicante, I've found the following, perhaps one of these companies might be worth calling?
Reactions: Happy Ant
i have actually tried some of those companies, but they all seem to suggest that if I purchase a battery pack the easiest solution would be connection via the cigarette lighter socket in the centre arm rest
I am trying some of those suggestions for fitting the Vantrue Hard wired kit VP01 and interchanging the relevant parts with the existing kit VP03 I know its only a small job if you know what you are doing but maybe too small for some of them to want to bother but will keep trying
Thanks to all for your valuable contributions
Reactions: Notfub
Adding a battery pack would take the load off your small 12v battery completely, so the suggestion makes a lot of sense. I've done this with my latest Formentor install but I've had the dashcam battery a few years and it's worked well. There is an additional expense both in the purchase and installation but given your 12v battery maybe smaller than most cars due to your MHEV setup, it's a good suggestion.
I hope you find a company that will help you out @Happy Ant
