tracktoy
Buyer's guide Common Issues on the MK3 Leon
Work in Progress
SEAT LEON MK3 – COMMON ISSUES
Below are the issues I have seen on both the Web and this forum that pop up time and time again.
1/ Front LED Lights turning foggy
Does not cause MOT Failure but looks like there is something on the inside of the light fitting check out https://www.seatcupra.net/forums/threads/headlights-haze-on-glass.456234/#post-4879806 there is also a link to a much longer thread on the subject.
2/ Rear Indicator Issue – Water Ingress
3/ Heater Matrix needs replacing
  • Some people see this first because the heater stops producing hot air across the board or on one side
  • Others have issues where they are leaking coolant, on the Diesels this is often seen after the DPF Regen occurs
How to replace can be found on multiple post on the forum but one example https://www.seatcupra.net/forums/th...ething-problems-but-sorted-in-the-end.476713/
4/ After Replacing Battery the dashboard lights up like a xmas tree
  • Take the car for a drive and the errors will self clear
  • Turn steering wheel all the way to the left and then all the way to the right can also clear all the errors
5/ Water in the boot spare wheel well
6/ Water Pump
Very common issue on these cars, starts as a slow leak as there is a lot of plastic in the pump it breaks down and leaks.
7/ Parking Sensor issues when near Renault group motors in slow traffic
Seen a lot on Pre Facelift not sure about Facelift cars but the parking sensors are upset when close to a renault in slow city traffic check out https://www.seatcupra.net/forums/threads/parking-sensors-mad-at-renault-group-cars.481828/
8/ Fuel Flap Actuator failure
  1. To be aware of you can code the actuator so that it does not auto lock every time you drive off, this reduces the number of times its used and increases the life of the actuator
  2. check out
    its a very simple replacement process and make sure that the end of the drain pipe is in the wheel well not inside the arch liner.
9/ Seat Bolsters on cars post 2014
  1. The White Plastic trims used to crack but also later seats had the same issue check out pictures here https://www.seatcupra.net/forums/th...k3-leon-do-today.379107/page-459#post-5011352
The following information is from the OBD11 Car health report under Car buying assistant
Please feel free to add in the comments and I will update the Resource so we have a complete list all in one placve.
Author
tracktoy
Views
3,479
First release
Last update
