Removing headlights - easy???
richardworrall
52
Derby
Tdi Ibiza 2005, how easy is it to get the headlights out as i really wanna dry them out completely as there is some condensation that will not dry out in the corner and its bugging me. Is it a one man job or am i likely to need help.
any help apprectiated.
just found the search facility and read all about it so dont need any help now, ill get used to this website soon hehe
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
Remove bumper - 3 or 4 torx screws around each wheel arch, 4 on top under the bonnet, 6 underneath and 2 behind the grills near the foglights. I think thats right..
Then remove headlights by undoing 4 screws on each - 2 on top and 2 just underneath the headlights that you can now get to with the bumper off! Then disconnect wiring harness.
Nov 25, 2007
1,891
Derby
that sounds about right i put to new h/lights in mine the other day due to condensation in them i swaped mine for the ones wit the red backing should only take ya about a hour.
richardworrall
52
Derby
i took the backs off, had full beam on for an hour and dried out perfect, now made my own vent kit involving two silicon pipes into each backing pointing downwards to stop unwanted dust and water getting in but allowing air to circulate. Seems to be ok for the past week.
ciano125
61
Barnsley, South Yorkshire
Can you post some pictures up for us Richard please?
richardworrall
52
Derby
right here goes....
They are 10mm holes and ive used clear silicone tubing thats flexible enough not to fold whilst bent and secured in place and sealed with superglue.
Any questions please ask.
drivers side cover from back
drivers side cover from inside
drivers side in situ
passenger side in situ
badleeroy
Great idea, was thinking about drilling my covers but was worried about dust,water etc getting in.Never thought about using tubing will try this when i get time. Well Done that man
kriso
Jan 29, 2007
2,325
Brighton
So glad I don't have to butcher my headlights to get rid of condensation. I think I got lucky when they made my car :D
ciano125
61
Good man, thanks for that. I must admit they are bigger than what I was planning on using, although I had thought that two tubes would probably be a good idea to help air circulate around them. Do you have issues with the back ones too or not?
Thanks again
Cian
