jay b
Hi guys, Ive got a 56 reg Leon FR TDI BMN engine, in at work confusing me! I deal with these cars all the time but have never had a non runner on one of these.. the basics...
engine turns over but wont run. Timing checked, all fine. Fuel pump working. Diesel seems clean and is pumping up from the tank. Havent yet carried out a fuel pressure test tho. The only fault code in the engine is "main relay malfunction in ciruit" Followed giuded fault finding, checked the power suply relay (even tried one from annother leon) and fuse, all ok, clicks when ign turned on. It seems the 2 main power feeds to ECU arnt found so I have started to strip the wires between the relay (in the engine compartment fuse box, nearside) and the ECU. I have found 2 slightly chaifed wires running to the ABS, had rubbed on the battery tray. Fixed them but the fault code wont go away, as soon as i eraze it, it returns. I will hopefully find the cause tomorow but if i havent i will be back on here with the exact fault code. It seems to have even baffled the technical help centre. Anyone else had this?
Maybe the fault code has nothing to do with the non start, but my aim is to clear the code before i try next steps...
Anyone that helps me will be helped in return, but please dont think that i will be able to answer lots technical questions all the time, I have enough of Seats at work every day! I need to get away from them in my spare time lol hope you understand! Thanks.
